11 speed shifter with 7 speed derailluer- Mtbr.com
Results 1 to 10 of 10
    Sep 2018
    Hey guys. Last week i ordered a gx 7speed derailluer with 11 speed gx shifter, beacuse the site did not have the 7 speed shifter.
    Got it today and could not get it to work perfect, it does shift kind of good but i was thinking if the 11 speed shifter and 7 speed shifter had different ratios in wire pull...
    I have a noname cassette right now, so the thing is, Should i buy the Pg720 cassette and the pc1130 chain, before trying a new shifter? Or can it be the both?
    Skickat från min EML-L29 via Tapatalk
    Reputation: LyNx's Avatar
    Not going to happen, you are wasting your time and $$, cable pull is way different between those 2. If you had 11spd and 10spd I think there are some adapters to make it work, but not 7 and 11 spd.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    since 4/10/2009
    Reputation: Harold's Avatar
    Buy stuff made to work together. Of course your stuff doesn't work right. You have a downhill derailleur on an 11spd shifter and hacked it together on some random cassette? Yes, put on the pg 720 made to work with the drivetrain, and track down the correct shifter. Don't forget to use the right chain, too.
    Sent from my VS995 using Tapatalk
    Sep 2018
    Actually all the gx shifters have the same pull ratio. So it will work, got it confirmed yesterday.
    The only difference then is the amount of clicks, wich you regulate with the wire tension in the rear derailluer.
    Sep 2018
    Quote Originally Posted by Harold View Post
    Like i said to lynx, the gx shifters have the same pull ratio. So a new cassette will do.
    So, WTF are you on here asking questions when you already know everything?
    Quote Originally Posted by lonnstrom View Post
    Sep 2018
    I asked the question 15 hours ago, i got the answer 13 hours ago by another guy. Just like i said in the reply, that "i got it confirmed yesterday"
    Why so mad?
    Sep 2018
    Why so mad?
    since 4/10/2009
    You ask for advice but refuse it...typical.
    Sep 2018
    Haha for **** sake guys, i put the same question in an other forum yesterday and got an answer from a SRAM mechanic that it will work. Before you guys posted
    Then i just told that to you in case there is other people reading this in the future
  1. GX1 10 speed vs. GX1 11 speed derailluer
    By Bos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2016, 09:16 AM
  2. 11 speed rear derailluer with 10 speed cassette
    By ScottW in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2015, 06:48 AM
  3. 10 Speed Derailluer with 9 Speed System
    By IntenseMack10 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-18-2013, 12:09 PM
  4. 10 Speed 3x shifter with 9 speed front derailluer
    By Hiebs915 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-03-2013, 08:29 PM
  5. Can I use a XTR 10spd front derailluer with 9 speed shifter?
    By trojans1993 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-12-2012, 05:15 PM
