• 09-14-2018
    lonnstrom
    11 speed shifter with 7 speed derailluer
    Hey guys. Last week i ordered a gx 7speed derailluer with 11 speed gx shifter, beacuse the site did not have the 7 speed shifter.
    Got it today and could not get it to work perfect, it does shift kind of good but i was thinking if the 11 speed shifter and 7 speed shifter had different ratios in wire pull...
    I have a noname cassette right now, so the thing is, Should i buy the Pg720 cassette and the pc1130 chain, before trying a new shifter? Or can it be the both?
    Skickat från min EML-L29 via Tapatalk
  • 09-14-2018
    LyNx
    Not going to happen, you are wasting your time and $$, cable pull is way different between those 2. If you had 11spd and 10spd I think there are some adapters to make it work, but not 7 and 11 spd.
  • 09-14-2018
    Harold
    Buy stuff made to work together. Of course your stuff doesn't work right. You have a downhill derailleur on an 11spd shifter and hacked it together on some random cassette? Yes, put on the pg 720 made to work with the drivetrain, and track down the correct shifter. Don't forget to use the right chain, too.
    Sent from my VS995 using Tapatalk
  • 09-15-2018
    lonnstrom
    Actually all the gx shifters have the same pull ratio. So it will work, got it confirmed yesterday.
    The only difference then is the amount of clicks, wich you regulate with the wire tension in the rear derailluer.
  • 09-15-2018
    lonnstrom
    Like i said to lynx, the gx shifters have the same pull ratio. So a new cassette will do.
  • 09-15-2018
    LyNx
    So, WTF are you on here asking questions when you already know everything? :rolleyes:
  • 09-15-2018
    lonnstrom
    I asked the question 15 hours ago, i got the answer 13 hours ago by another guy. Just like i said in the reply, that "i got it confirmed yesterday"
    Why so mad?
  • 09-15-2018
    lonnstrom
    Why so mad?
  • 09-15-2018
    Harold
    You ask for advice but refuse it...typical.
  • 09-15-2018
    lonnstrom
    Haha for **** sake guys, i put the same question in an other forum yesterday and got an answer from a SRAM mechanic that it will work. Before you guys posted
    Then i just told that to you in case there is other people reading this in the future [emoji28]
