10 Speed Cassette...options other than XX- Mtbr.com
Results 1 to 8 of 8
    Reputation: packfill's Avatar
    Aug 2005
    I'll looking to possibly drop the cash for the new XX group. I have an extra set of wheels for my race bike. The big issue that i'm having with the group is the cassette. The cost is hard to swallow to begin with, but buying two is almost obsurd. Does anybody know when we can be expecting something other than a XX 10 speed cassette?
    thanks
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Why not try a Sram OC-1070 11-28 road cassette???
    Aug 2005
    because it's going on a 29r....and i live in Colorado.
    Handmade in Switzerland
    Reputation: maettu's Avatar
    Not cheap, but maybee an option...
    http://luckynino.blogspot.com/2009/0...-cassette.html
    Cheers mat
    Reputation: LyNx's Avatar
    Didn't you read his NIC, he's only there as pack fill, he's not an actual fit, strong racer boy who can push such gears
    Quote Originally Posted by mtnbikej
    ......FYI you can get custom cassettes made for about 1/2 that, Harris Cyclery (AKA Sheldon Brownes) store does it, not sure who else.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Reputation: uzurpator's Avatar
    Dec 2005
    Quote Originally Posted by packfill
    thanks
    uzurpator's 10 speed wide cassette formula:
    Ingredients:
    10 speed road cassette of size you want ( 12-27 for example )
    10 speed cassette spacer (2.35mm thick, 17mm I.D.)
    large "mountain" sprocket (30/32/34/36, whatever )
    1 rear wheel.
    Take wheel. Mount 'mountain' sprocket, then put the spacer. Now mount 9 of the road cassette cogs, lock the contraption with a lockring ( if you have chosen 11-xx cassette for the conversion, then you might need a new lockring, one fitting 12T+ first cogs ).
    Does this actually work?! It's a bit of a jump to the 36, but, he'll, you may have just made a bunch of 'racers on a budget' day!
    Dec 2005
    Why should it not work? People have been doing this for touring bikes for pretty much eternity*.
    *eternity is defined "from the first time shimano made 10 speed gruppo"
