Tubeless issues Roval 29 rims on my '12 Camber Comp- Mtbr.com
    About 6 months ago I converted to tubeless on my '12 Camber Comp. The LBS used the wheels as is (red tape) installed the tubeless stems and added Stan's fluid. This week I noticed the rear tire losing about 10 lbs between rides and now I'm seeing residue at around the stem and some spokes.
    Can I get by with a simple wheel/tire cleaning and fluid recharge or do I need a retape? I would be using Gorilla Tape.
    2012 Specialized Camber Comp 29er
    Trek 9800 OLCV, XT upgrade 26er
    KHS Fleetwood
    Schwinn 20" Fastback 5 speed stick shift
    Reputation: rondre3000's Avatar
    Sounds like your best bet would be to retape. Don't use Gorilla tape unless you have to. Use Stan's, the Specialized strips or Orange Seal strips.
    Reputation: Trail_Blazer's Avatar
    May 2012
    Use Stan's, the Specialized strips.
    You can wash off the residue inside or outside the tire with water and a sponge.
    Ended up pulling the tire off cleaning up the loose stuff reinstalling with 4 oz of fluid. What a mess, next time may just add a couple oz through the valve.
    KHS Fleetwood
  1. Replies: 7
    Last Post: 05-14-2013, 10:22 AM
  2. Rim Tape Size to Run Tubeless on '13 Camber Comp
    By goatman2304 in forum Specialized
    Last Post: 03-12-2013, 01:14 PM
  3. '12 Camber Comp 29r to Tubeless
    By lastplace29er in forum Specialized
    Last Post: 11-04-2012, 04:24 PM
  4. 2012 Camber Comp 29-Tubeless ready?
    By Eazy_E in forum Specialized
    Last Post: 08-01-2012, 01:53 PM
  5. Replies: 17
    Last Post: 01-18-2012, 06:40 PM
