Reducing weight on 2011 S-works Epic?- Mtbr.com
Results 1 to 14 of 14
    So now got my weight down to approx race weight. Now looking at my 2011 Epic S-works 29er and wondering how I could lighten it. It's so damn light now that I'm finding it hard to think of something other than titanium bolts!
    Replaced the original bar, as didn't like the position, with 680 wide Truvativ NOIR carbon with a slight rise. Maybe a replacement bar would save a few grams (assuming it's worth it?)
    So anyone lightened (or got suggestions how to) an S-works Epic, how and how much $ ( and don't tell me BB ceramic bearings :P)
    Reputation: WR304's Avatar
    You could always do something similar to 417markg's 2010 S-Works Epic. It's not a cheap approach but would drop significant weight (at the expense of some reliability).
    http://forums.mtbr.com/showpost.php?...postcount=1051
    Jan 2009
    tuff task!
    Quote Originally Posted by Hostilemonk View Post
    I went tubeless, as the 29er tubes are 170g....stock post and saddle have a combined weight of 500+ grams....put in a Shimano PRO Tharis and a carbon rail PRO saddle, and foam grips.
    Thats it....actually went heavier on the tires (IKON's 600g) because the Renegade's are so specific...needed a wider all rounder. Last year I rode the Renegade 26X 2.1....even it was better than these narrow 1.95 with taller knobs.
    So my EPIC 29er is 22.3lbs.
    later...LC
    Reputation: GTR2ebike's Avatar
    May 2010
    Scrub Rotors
    Lighter Post (Ritchey Superlogic with Ti bolt will save 100 grams)
    Carbon Rail saddle
    Foam Grips
    2012 SID Fork - If you can get one
    If your a serious WW then
    -Carbon Ti seatpost clamp
    -syntace x-12 rear axle
    The Other Dude
    Reputation: jut8's Avatar
    I went 1x10, with foam grips, toupe saddle, fast trak front, renegade rear, eggbeater ti pedals, some ti bolts, and a few other goodies got me down to 21.6lbs with pedals, cage, and a computer, all ready to race.
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    My cheap and cheapish weight savings are as follows and used on my S Works 2011 Epic 26er and will be doing the same or similar on my S Works Epic 2012 29er
    Tubes for tubeless - 200g
    Swap grips for 'Poshbikes' nitrile foam grip(they honestly don't slip at all) -40g
    Stock post for Thomson Masterpiece with Ti bolts. -100g
    Saddle for toupe pro( masterpiece good for carbon rails. - 50g.
    Swap chainstay protector for 'Lizard Skins' carbon leather protector. - 43g.
    RIDE...
    Reputation: MarcoL's Avatar
    do not use the scrub rotor, it is too noisy!!!
    use formula brakes, hope rotors, esri foam grips, ritchey seat post, a romin carbon saddle, my 2 cents...
    KCNC seatpost (160 g), Tune saddle (95 g), foam grips (12 g), Schwalbe Rocket Ron (420 g) and these wheels (1190 g):
    http://www.actionsports.de/de/Laufra...tz::29186.html
    Excellent info guys - thanks - gone to tubeless and S-works tyres due to surface here - will now peruse the options and do some costing
    Thanks - and keep the suggestions coming if you have any more
    Quote Originally Posted by dirkinho View Post
    Can you get DT Swiss 180 rear hubs with a 142x12mm thru axle option? Apparently they're quick release only so you couldn't use the back wheel on a 2011 S-Works Epic.
    http://www.bikeradar.com/news/articl...wheels--30514/
    Right, no idea but you can have it built with other hubs.
    At least there are definetely lighter options than the Rovals!
    Formula Brakes and 1 piece Rotors
    Masterpiece Seatpost
    Fizik Aliante Carbon Rail Saddle
    ESI Grips
    Easton Monkeylight Bar
    Syntase F109 Stem
    Tubeless Renegades
    Eggbeater 4 Ti pedals
    21lb 9oz
    May 2010
    Quote Originally Posted by jeddog69 View Post
    ESI Grips
    Syntase F109 Stem
    Tubeless Renegades
    21lb 9oz
    It comes with a Syntace F109 Stem
    How about Wheels: Easton EC90 .
  1. Replies: 17
    Last Post: 06-24-2011, 09:09 AM
  2. 2011 S-works Carbon Epic frame weight
    By Leighc in forum Specialized
    Last Post: 03-29-2011, 08:26 AM
  3. 2011 Epic S-Works and S-Works 29
    By M0riarty in forum Specialized
    Last Post: 10-07-2010, 03:56 PM
  4. Replies: 12
    Last Post: 09-06-2010, 06:52 PM
