options other than sworks cranks for epic carbon..- Mtbr.com
Results 1 to 3 of 3
    Reputation: zippy895's Avatar
    seems like sworks double ring 175 cranks are back ordered till april? any other option that will fit 09 epic carbon (84mm) w/ a bb30 setup?
    Reputation: ARider's Avatar
    Feb 2005
    XTR (or any Shimano) w/ Shimano BB adapters.
    Reputation: chuckji's Avatar
    It's not BB30, it OSBB (Over Sized Bottom Bracket).
    Simply, you can use the same bearings as BB30 but the width of the BB is larger on the Specialized.
    Extralite and Lightning both have a crank that will fit
    I'll be installing a Lightning on my S-Works Stumpjumper - I have the S-Works crank on my Epic.
    Other option is to use the Shimano bearings that came with your Epic and install a Shimano/compatible crank.
    Probably same response you got on the WW forum...?
