Need some help with components to build my hard tail 29er comp!- Mtbr.com
Results 1 to 6 of 6
    Caution;  Merge;  Workers Ahead! Need some help with components to build my hard tail 29er comp!
    Hey guy, i just recently get 2011 specialized ST 29er comp frame, and i want to build it with x9 components, this bike gone be 2 by 10. The components that i consider so far Sram X9 Red 2 x 10 Crankset 175mm 28-42 with bb30 NIB and SRAM X9 Rear Derailleurs 10sp, what kind x9 front derailleurs that would be good for this 2 components?
    what is Compatibility should i use 38t or 42t?
    Reputation: S-Worker's Avatar
    THe FD you need is not specific to 42 or 38t. You need a high mount toppull FD with 34.9 clamp. Just choose the x.9, it will work just fine.
    Quote Originally Posted by S-Worker View Post
    would this parts work fine SRAM X9 2x10sp High Clamp Front Mech or SRAM X0 2x10sp High Direct Front Mech?
    The X.0 seems to be a direct mount FD considering the term "direct" in its name. So no, this one would`t fit.
    The X.9 is fine as long as you take the toppull version for cables coming from the top tube downwards. There is also a downpull for bikes where the cable is routed from the bottom. And the clamp diameter must bei 34.9.
    Correction: the FD is dualpull so don`t worry about this. It will fit anyway as long as it has a 34.9 clamp. See here in a german onlinestore. The picture is wrong as written in the description. It shows a low clamp!!
    Bike 24
    yes i just find out too that it was dual pull, and let me ask you something,
    i was thinking to build this bike with 100mm fork but the stock fork with the bike is only 80mm of travel, should stick with 80mm or 100mm of travel?what is a good choice?
    Kenny GT I have sent you a PM about some components you might be interested in.
    jscot111
