EPIC 29er question: Q-Factor 156, work?- Mtbr.com
Results 1 to 7 of 7
    Jan 2009
    Just wondering if anyone has installed a XX BB30 Crankset on a sworks EPIC 29er.
    Q-156.....medium frame, 170mm crank arms.
    I have concerns.
    Reputation: Alexgonzalezmi's Avatar
    Have you tried and it's not working?
    Reputation: S-Worker's Avatar
    You only have to read the Sram XX frame fit spec sheet and do some measurements with your frame.
    Mar 2012
    I just purchased an XX 2x10 BB30 Crankset with Q-Factor 156 and 170mm crank arms and had them installed on my 2011 Specialized Epic Carbon Comp 29er. Yes it fit but the clearance is close. I rode it home from the shop with no problems but haven't tried in the trails yet. I can't imagine flexing my frame enough or putting so much sideways torque on my pedals to ever cause the arm to rub the chain stay.
    Reputation: trucco's Avatar
    Feb 2012
    Quote Originally Posted by bmariani2 View Post
    So on your opinion, which would be the best option on the XX 2 X 10?
    hi... i just installed and crankset with q factor 156 and the right arm is 2 inches clearance.. but when i m going up on hills hit with the chain stay..... so i dont know... CAN I aDD and spacer to avoid it?
    old fart
    Quote Originally Posted by alonso View Post
    Probably not enough. You have a wave washer on the LHS of the crank to allow for variable end float. The obvious thing would be to use multiple PF30 washers on the LHS to replace a couple of mm of the 4mm spacer, but then you will need to work up a way to work with the bearing shield (the 4mm spacer mates with the shield).
  1. Epic Comp 26 ....which Q factor ?
    By Barrickuda in forum Specialized
    Last Post: 01-12-2012, 08:17 AM
  2. Sworks Epic 29er question
    By williford in forum Specialized
    Last Post: 02-28-2011, 01:20 AM
  3. Question on 2011 Epic 29er 142+
    By TurnerConvert in forum Specialized
    Last Post: 10-12-2010, 02:04 PM
  4. Low Q Factor 2x9 setup on 2007 EPIC
    By RideToLive in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2009, 12:39 PM
  5. Q factor of the spech cranks on the S-work epics?
    By bellullabob in forum Specialized
    Last Post: 03-26-2009, 08:17 AM
