Enduro torque specs?- Mtbr.com
Results 1 to 7 of 7
    kneecap
    Hey enduro folks, since I'm waiting for the local trails to dry up some here in so. cal. I figure its an good time to catch up on some bike maintenance. Does anyone have torque specs for rear linkage (swingarm/shockmount/etc.) for an 02/03 enduro? I'm a hands on guy, and unless bearings are trashed I'll just pop seals off, clean & regrease. Any extra heads up tips perhaps? Thanks in advance, Kit
    contains quinine
    Reputation: Debaser's Avatar
    i was poking around at special ed's site, and they've got numerous downloads - including a tech manual. you might try that out.
    Take the long cut, we'll get there eventually.
    BMF
    BMF is offline
    90 - 110 inch pounds for the upper shock mounting bolt.
    180 - 200 inch pounds for the lower shock mounting bolt, use blue locktite.
    120 - 140 inch pounds for the link bolts, use blue locktite.
    Tip - make sure there's no dirt in the hex sockets on the link bolts & you use a decent Allen key. The bolts are aluminium & it's easy to round the socket off. I also found 3 from 4 bearings in the link had shot it after just 8 months.
    Gravity Rides Everything
    Reputation: endurowanker's Avatar
    Quote Originally Posted by BMF
    anybody know if these numbers are legit? I'm about to use em....
    Reputation: phil.'s Avatar
    Quote Originally Posted by endurowanker
    Numbers represent torque in*lb.
    b= blue loctite required
    BB Pivot Axel: 200-230b
    BB Pivot Nut: 200-230
    BB Pivot Bolt (02 Enduro only): 180-200b
    Dropout Povot Bolt: 70-90b
    Shock Link @ Frame Pivot Bolt: 120-140b
    Shock Link @ Seatstay Pivot Bolt: 120-140b
    Upper Shock Eye Bolt: 90-110
    Lower Shock Eye Bolt: 180-200b
    Quote Originally Posted by phil.
    do you know if these would be the same for my '03 epic s-works??? i cannot get a straight answer out of ANYBODY (inclucing specialized)!!!!! there are a few places on the link and shock that tell you, but nowhere else...inclucing the manual or on-line!
    thank you in advance..
  1. FOX Enduro prototype seals available !!!!!!!
    By DGC in forum Shocks and Suspension
    Last Post: 02-21-2004, 08:41 PM
  2. Enduro Expert vs Cake 1/2 DLX vs Liquid 55
    By seely in forum Bike and Frame discussion
    Last Post: 02-19-2004, 10:06 AM
  3. Who uses a Rohloff Speedhub ?
    By Doggycam in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2004, 11:19 PM
  4. Spoke Tension specs for various rims?...
    By Ricko in forum Wheels and Tires
    Last Post: 02-04-2004, 06:14 PM
  5. Enduro specs
    By skiahh in forum Specialized
    Last Post: 01-12-2004, 06:59 PM
