Dropout (Horst) Pivot bolt keeps loosening on a Epic Comp '12- Mtbr.com
Results 1 to 2 of 2
    Nov 2008
    I bought a used Epic Comp '12 frame from my LBS, and the dropout pivot bolt (referring to page 5 here) keeps loosening out, resulting in creeks coming from the frame, mostly when riding uphill.
    Is this a known issue / has anyone else experienced this problem?
    The bike is now at the shop being serviced. The manager said they will apply Loctite to hold the bolt in place - is this an acceptable solution or does this mean there may be something faulty in the frame?
    I have a 3-month warranty on the frame, so i need to act fast and follow thru this issue.
    Any feedback would be much appreciated.
    Reputation: Devastazione's Avatar
    Dec 2009
    Yeah Loctite should fix you up with that.
    Roadie DNA,mtbike curious.
  1. Pivot Mach 4 frame/dropout stripped @ hanger bolt - 2010
    By Rollin'in'Zona in forum Pivot Cycles
    Last Post: 10-30-2013, 05:43 PM
  2. Preload bolt loosening.
    By bill34di in forum Nicolai
    Last Post: 06-01-2012, 10:54 AM
  3. Main pivot pin loosening
    By brant in forum Titus
    Last Post: 05-29-2012, 12:03 PM
  4. Link Bolt Loosening?
    By Lev in forum Ibis
    Last Post: 11-14-2011, 06:22 PM
  5. Epic dropout pivot question
    By ErikGBL in forum Specialized
    Last Post: 03-26-2011, 03:55 PM
