Anyone running a coil shock on an Enduro?- Mtbr.com
Results 1 to 6 of 6
    LukeB
    Feb 2005
    Just wondering what spring weight you're running. i've got a 650 on mine, and I'm 11 stone- something feels not quite right (although it is getting the full 6" travel- it's got a longer stroke than the old air). It reaches full travel easy, but something feels wrong, and I think I might be running too stiff a spring.
    Any ideas?
    http://www.m-bike.tk
    AndyFSR
    Reputation: andyfsr's Avatar
    Oct 2003
    Too Stiff
    What weight does a stone translate into?
    I weigh 93 kilos (204 lbs) and use a 650 lb spring and have no problems.
    Are you contacting the seat post at full compression?
    It is possible that the shock collar could be binding on the link during compression.
    Did you try removing the spring, remounting the shock and checking for binding?
    Good luck.
    If you weigh less than me, try a lighter spring.
    One last thing, is it also possible that you are getting coil bind? Where the coils contact before the shock has reached full travel?
    A3
    ...I go downhill like a falling safe...and climb like I'm dragging one...
    LukeB
    Feb 2005
    In new money I'm 70 kilos. Shock bind- hadn't thought of that. The coi's definitely not binding on the shock, but I'll have a look to see if it's hitting the linkage.
    Sep 2004
    I have the same rig
    I have the same rig you do 2002 Enduro Expert FSR.... I want to upgrade the rear shock as the 2-4ft drops is killing the shock and I want to get a freeride shock.... do you know what shocks can fit on the bike???
    Mar 2005
    It is quite common here on the shore. The guys at dizzy cycles do it all the time. One guy went as far as to put a triple crown fork on his also.
    AndyFSR
    Oct 2003
    Coil Shock
    Quote Originally Posted by dfrancefort
    It seems that most of the coil shocks available, Fox, Prgressive, Romic, etc... are all 200 mm (some are shorter), which is about 10mm longer than the stock unit. Check prior posts concerning Enduro Shock upgrade, a lot of info is in that thread.
    Mine is a Fox coil with i2i of 200mm and it works really well.
    A3
  1. Which Coil Shock for 2004 Sworks Enduro
    By scarlet in forum Specialized
    Last Post: 10-20-2004, 11:31 AM
  2. Replies: 45
    Last Post: 10-12-2004, 12:04 PM
  3. enduro coil shock
    By handlebars in forum Specialized
    Last Post: 05-01-2004, 10:19 PM
  4. Enduro Coil Shock: Interesting
    By Bike Daddy in forum Specialized
    Last Post: 04-19-2004, 01:19 PM
