2019 Stumpjumper EVO thread - Page 11- Mtbr.com
Page 11 of 11 FirstFirst ... 7891011
Results 2,001 to 2,076 of 2076
  1. #2001
    First ride
    20190921_084948_023 by Sales Punk, on Flickr
    Will never be this clean again....
    20190921_072853 by Sales Punk, on Flickr
  2. #2002
    Reputation: kwapik's Avatar
    Feb 2016
    Looking good! So what's your thoughts on the riding and handling - aluminum frame versus the carbon fiber?
  3. #2003
    Jun 2019
    i can see you have the super cool eeWings crankset
  4. #2004
    Jan 2017
    Hi All,
    Just pulled the trigger on a 29 Alloy frame. Will be a bit till I'm able to build it up. Just curious on what the consensus is on the fox perf rear shock? Worth keeping and riding at 50mm for a bit? Go straight to 55mm with the removal of the shock reducer right off the bat? Sell it and get something else?
  5. #2005
    Quote Originally Posted by kwapik View Post
    I was surprised at how much of a difference I felt between the two. So many changes that it is hard to attribute to just one thing, but the bike felt even more composed. It just monster trucks through everything and feels much quieter. Overall I would say the carbon has a much more damped feel to it which I like much more. The coil feels really good in my local terrain and the Grip 2 damper is a big step up over the Rythm setup.
  6. #2006
    Feb 2016
    Sounds like a good upgrade. Thanks for the comparison. Oh yeah, have fun in Whistler!
  7. #2007
    Oct 2011
    Quote Originally Posted by swift685 View Post
    Attachment 1276873
    Freshly completed 29er conversion on a 27.5 EVO Pro S2 Frame!
    BB height is 348. Standover is perfect (31" Inseam). 160 / 155 travel. Great tire clearance. Not much reason to spring for the 29 frame given the results. Spot Fin' On!
    I assume you have 155mm travel in the rear, which would be a 210x55 shock? No clearance issues with the 29 rear tire?
  8. #2008
    Sep 2019
    The bike has evolved
    Heres my 2020 Stumpy EVO Carbon S2 27.5. The Frame replaced a 2015 Enudro Evo 180mm front and back, which was nice and slack but had too much travel and weight for my riding.
    I'm really impressed with the new bike, i feel better in the berms and the bike is much more lively and poppy owing to the shorter travel and stiffer frame.
    Full XT 12 speed drive-train
    DT wheels and hubs
    Code Brakes
    Renthal Cockpit
    DHX2 - 500lb spring
    Fox 36's lowered to 160mm - 51psi and 2 tokens
    160 command dropper.
    i'm 5'9 " / 176cm and weigh 154lbs / 11 stone
    S2 frame fit feels perfect to me.
    Weighs in at 13.9kg / 30.7 pounds
    Bike is super fun, looking forward to more shredding
    Cheers
    Attached Thumbnails Attached Thumbnails 2019 Stumpjumper EVO thread-p5pb17767875.jpg
  9. #2009
    Jun 2019
    Quote Originally Posted by endoguru View Post
    Yes, sir. Zero issues.
  10. #2010
    Jun 2019
    QUESTION: For anyone running a 160mm fork upfront. What is your sag %?
    I'm running 23-25% sag on the fork and 29% sag on the shock with no wheel flop but if I try to run 20-22% sag on the fork then the wheel flop kicks in and doesn't make for the smoothest steering. Any suggestions?
    My stem is already dropped.
  11. #2011
    Oct 2011
    Are you able to run it in the low setting or high only? I really want to try this, but want to be sure before spring for a new fork and wheels.
  12. #2012
    May 2019
    What pressures are people running in their dpx2. I am only 130lbs and am stuck running 190 psi with the biggest volume token to avoid bottoming out. I still bottom out more than I would like but if I add any more there is not any small bump compliance. Specialized recommends 155 (with .86 volume token) for my weight but that is complete bs.
    Also seriously thinking about moving to an x2. How progressive does it get with 4 tokens?
  13. #2013
    Stumped IG: BikesNBuds
    Sep 2019
    Hello from a new EVO rider
    Hello everyone, new to forums, and just built up a 2020 29 Evo alloy frame in size S2, and so far this thread has helped out a lot! Didnt know about these forums prior to my build, but I myself already had intended to use a 160mm Lyrik fork up front, glad to hear i wasnt the only one!
    A little about me, been riding for about 2 years, with my first bike being an 18 Stumpjumper 29/6Fattie in alloy. Its helped me grow in fitness and skills, until I rode a Pole EvoLink 148 in spain for 2 weeks on holiday and that just blew my mind. I still loved my first stumpy, but when I heard this EVO would come out and have similar geometry. I knew I had to have it. Bought the alloy frame from my LBS and transplanted parts over from my first Stumpjumper'(160mm Lyrik fork, contact points, cassette, stem) The rest were all brand new.
    BUILD
    S2 Frame. Satin Cast/battleship grey color. Full invisiframe wrap in matte. Rockshox Lyrik RCT3 (3 tokens, 51 Psi) Stock rear shock
    GX 11spd groupset - Ethirteen TRS Race 11spd 9-46 cassette + Absolute black 30T oval chainring
    Code R brakes
    Spank spike stem and 760mm vibrocore handlebars
    Ergon seat and Grips. PNW 150mm dropper.
    Hunt Trailwide 29 wheels
    Maxxis Dissector 2.4 rear with huck norris insert
    Maxxis DHF 2.5 up front
    I built this bike up knowing my time on the bike is 65% local trails in the los Angeles Forest areas and 35% bike park, doing small to medium drop and jumps. Ive ridden in this build for about 3 weeks on both trail and bike parks and have dialed in my fork to feel playful and poppy.
    The rear shock on the other hand I have come to you gurus for advice. I put a DVO topaz on my old stumpjumper and that transformed that bike. The stock DPX2 feels nothing like it and I would like something more confidence inspiring like that topaz made my old stumpy feel. The topaz allowed the bike to talk to me if that makes sense. Id like that again
    I would have pulled the trigger on a 210x50 DVO Topaz again for this EVO but now im reading so much about coils, removing spacers and fitting 210x55 shocks, increasing the rear travel ahh so confusing.
    So gurus, for someone who spends more time on trails than bike parks, would a Topaz or even a Super Deluxe but suffice, or is coil really what this bike needs given its kinematics. (which in that case im leaning towards a EXT Storia for the bottom out tech they have)
    Oh also, is there an issue with loose headsets? bought a cane creek set that was supposed to work fine but never could quite get tight enough. Just ended up putting what came with the box
    Thanks guys!
    Attached Thumbnails Attached Thumbnails 2019 Stumpjumper EVO thread-img_0865.jpg
  14. #2014
    Sep 2017
    Quote Originally Posted by snoball218 View Post
    BUILD
    Code R brakes
    Thanks guys!
    Funny, I used to have Large 2018 Stumpjumper Comp in size Large with Diamond 160 up front and Topaz for the shock. Last year I sold the bike and built Pole Taival and it was perfect in fit and geometry wise. But since I moved from NYC to Utah, I wanted FS. Evolink was out of my price range so I grabbed Evo S3 27.5 frame, but will build as 29er. Cane Creek Helm Air up front and thinking of CC DB IL Air. There are few brand new 210x55 under $300 on eBay.
    I even considered Hunt wheelset, but decided to go fancy with Project 321 hubs
    Sent from my Pixel 3 using Tapatalk
  15. #2015
    Reputation: Macharza's Avatar
    Jun 2013
    I rather keep the sag the same on both ends. Keeps the geometry the same, the Sag percentage is then to your liking
  16. #2016
    Oct 2011
    This question has probably been asked before, but here goes. I have a buyer for my S Works Carbon Evo 27.5 S3, but only if he can put a Fox Float X2 on. Does anyone know if the X2 will fit on this frame with no issues?
  17. #2017
    Dec 2018
    I think a guy put up a post only recently showing it worked, the carbon frame had more clearance than the alloy too. It's a very tight fit, however only at full extension/unladen, once it moves through the travel the gap between aircan and frame grows.
  18. #2018
    Jun 2019
    ENDURO POLL: Any else here considering upgrading to the new 2020 Specialized Enduro?!
  19. #2019
    Sep 2019
    The Hunt Trail wide wheelset has been great so far, cant report anything bad on them yet, but for the price point (with shipping to the US) was too hard to pass up.
    I see the CC DB IL 210X55 you're talking about on ebay. that price is also too good to pass up anyone wouldnt happen to know the mounting hardware needed for the alloy evos? :P
    Despite the price I still might go for DVO for self serviceability, but taking a quick look at the instructions, looks easier said than done
  20. #2020
    BLAH BLAH
    Sorry to spam it up but I have SJ tuned Rock Shox Super Deluxe Ulitimate 210mm x 52.5mm up for sale
    Here
    Whats this line for?
  21. #2021
    Sep 2019
    2020 Enduro
    based on this comment below from a well written review of the 2020 Enduro, i'll be keeping my stumpjumper evo for a long while. Although id be opened to a test ride changing my perception.
    "But I want to emphasize ďrace bike.Ē For this is not a playful, poppy, jump, whip, jib, fun-time machine. This is a racing tool and all business. Itís not a trail bike, and itís not a park bike. Itís for taking the straightest, fastest, line between two points, squashing jumps, and finding all the traction so you can brake harder, and drive it harder through turns. Itís about holding onto as much speed as possible at all times and giving you the confidence to push your hardest. Point, grip, brake, sprint, and repeat: this new Enduro is speed focused."
    Last edited by blackjack88; 10-01-2019 at 01:05 AM. Reason: added quote for context
  22. #2022
    Feb 2016
    I'm sticking with the Evo. It handles everything I throw at it.
  23. #2023
    Sep 2014
    Quote Originally Posted by blackjack88 View Post
    based on this comment below from a well written review, i'll be keeping my stumpjumper evo for a long while. Although id be opened to a test ride changing my perception.
    Yes
  24. #2024
    Jan 2014
    To anyone who has replaced the stock handlebars with anything else: are you willing to sell me the stock bars? Let me know.
  25. #2025
    A few pics from Whistler
    20190928_142033 by Sales Punk, on Flickr
    GH010032_1569621844693_high by Sales Punk, on Flickr
    20190928_151546 by Sales Punk, on Flickr
    Bike was amazing, can't believe how capable this 140/150 bike is even on some very nasty trails.
  26. #2026
    Dec 2018
    Pop your fox Bushings and Pin out, put into the Cane Creek, bottom side of shock nothing needs to be done, feed the flip chip in.
    Don't need to purchase anything! Well worth doing.
  27. #2027
    Reputation: elsinore's Avatar
    Jun 2005
    Quote Originally Posted by brash View Post
    Anyone know the mounting hardware size? Mine is worn out and I canít find the dimensions anywhere.
  28. #2028
    Oct 2019
    For all those wondering, a 2020 x2 will fit on my s2 27.5 alloy with about 1/16" to spare. Attached are images of the exact part number as well as full extension and full compression of the shock. Got about 10 hard miles on it so far, and no rubbing due to frame flex.
    2019 Stumpjumper EVO thread-20191002_153030.jpg2019 Stumpjumper EVO thread-20191002_152912.jpg2019 Stumpjumper EVO thread-20191002_153226.jpg2019 Stumpjumper EVO thread-20191002_153244.jpg
  29. #2029
    Quote Originally Posted by Hy24den View Post
ID:	1283717Click image for larger version.
ID:	1283719Click image for larger version.
ID:	1283721Click image for larger version.
    I tried to mount an X2 on an S3 and it would not fit. Just an FYI.
  30. #2030
    Jun 2019
    I have just taken delivery of an alloy S2 29er, and I have a 210x55 X2 from my Rocky Mountain that I will attempt to fit at some point.
    will be interesting to see if it fits.
    Did you transfer the shock hardware over from the original shock? Or buy new?
  31. #2031
    Sep 2019
    Easy peasy after all! Thanks! 😁
  32. #2032
    Oct 2018
    Anyone here replaced the original FSA headset? And if so what did they replace it with?
    Mine (2020) has been giving me greif recently! Stripped it down and both the fork crown race, and even more so the top version is pitted and worn, it's like the bearings aren't moving and instead the are rotating on the aluminum. The most obvious thing here would be the headset is loose, but I'm very sensitive to that so I know it's not the case.
    The bearings are both in good order, the bike is 3 months old and not seen that much action yet.
    Taking the bearings out of the frame I noticed the lower bearing is a nice fit, but the top bearing slops around in the frame, measured it and there's 0.25mm of clearance (while the bottom has nothing like this).
    The I.D. of the top of the frame is 42mm while the bearing is 41.75mm - anyone else have similar issues?
    I can't tell if the frame is incorrect or the bearing is underspec.
  33. #2033
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    Which begs the question: Why does Specialized insist on making frames that way?
  34. #2034
    Nov 2018
    I am planning to do S3 27.5 convert to 29er wheels and fork. I know some of you have already done it and i would like to ask you are my calculations right: Is the BB height around 347mm in low setting? And is there still enough clearance between seat tube and tyre when bottoming out?
    Thank you
  35. #2035
    JCL
    JCL is offline
    Quote Originally Posted by moity View Post
    Highly likely the bearing will be well within tolerance. Integrated headsets like what Specialized and a few others use are a terrible idea IMO. If you happen to get a frame that is towards the end of the mill tools life or isnít adequately cleaned or cooled during machining you will get a sloppy fit and a headset that creaks or repeatedly loosens. Also a pressed in headset cup can be 7000 series aluminum and heat treated/anodized which is far more resistant to being ridden loose. Iíve seen two Specialized frames ruined by being run loose for a ride which wouldnít be an issue on frames with pressed cups.
    Loctite bearing retainer can help if you have a sloppy fit.
  36. #2036
    Contact Spec, sounds like a warranty issue to me. Bearing should not be loose in the cup. One note is to make sure you grease the bearing and cup. This will help eliminate creaking/popping for a while. I typically have to redo the grease every few months.
  37. #2037
    Quote Originally Posted by coiler-d View Post
    Specialized is not the only one, most of the manufacturers have moved to this process including Santa Cruz. Not sure why, but my guess is something to do with cost.
  38. #2038
    Oct 2018
    Quote Originally Posted by Salespunk View Post
    Thanks for the comment, will let you know how I get on when I can take it back.
  39. #2039
    Quote Originally Posted by HuiGe View Post
    Thank you
    Yes, that's about right on BB height. I have run mine as full 29er and as mullet. Both good. For running as 29er, clearance is fine, even with the spacer taken out of the shock for longer travel.
  40. #2040
    Mar 2019
    I recently tried the 27.5 to 29 setup. It works fine, clearance is great with 55mm stroke, and the BB height is basically like a normal enduro bike. Great for racing/bombing down rough stuff. Only problem is super super slack HA. You will get 62.6HA if u use a 160 fork. U will fell the front slipping away on loose turns. Shame cannot use Angleset for this frame
  41. #2041
    Feb 2013
    a longer stem will help and also roll the bars more forward. Helped me.
  42. #2042
    boatesfamily9
    Aug 2019
    I'm about 20 rides in on a new 27.5 comp alloy. Rolling the handlebars forward made a huge difference in controlling the bike while climbing and descending.
  43. #2043
    Sep 2017
    Just finished building my 27.5 frame with 29 components. Fork is set at 150mm but will try 160 once I have enough rides.
    Not a fan of Fox shock and going to replace with Cane Creek.
    Question: should I go with coil or air IL or CS? I have Helm Air up front and really like it's tuneability.
  44. #2044
    Dec 2018
    Robik, I have both the DB Air CS and DB Coil IL and I think the Air CS is the better choice IMO but only for progression on ramp up. The coil is obviously butter on small bump but these bikes are not progressive enough to avoid slamming the bottom out bumper quite a bit, upping spring rate and running 20-25% sag just loses the small bump compliance and you are not really getting the full benefit of a coil.
    Just one blue band spacer (or none) in the AirCS at 30% sag works well.
    Edit: sorry just realised you were comparing both Air shoks not the coil, Go with the Air CS imo
  45. #2045
    Dec 2018
    I've just booked to fly to NZ to ride queenstown and surrounds for 2 weeks.
    Having never used a bikebag before, am I going to have issues fitting a 29'er S3 in a typical bike bag? Anyone else travelled with the Big 29er before.
  46. #2046
    Nov 2006
    My S2 barely fit in an EVOC Bike Bag Pro. Youíll be able to make it work if you let air out of the shock and compress the bike a bit.
    Evil Following
    weareelements.com
  47. #2047
    My S3 29 fits fine in my Evoc bag
    20190923_220434 by Sales Punk, on Flickr
  48. #2048
    Dec 2018
    Thanks. Iíll borrow my buddies and have some practice runs
    Canít wait. I feel this is where the big stumpy will shine.
  49. #2049
    Aug 2019
    Cane Creek Shock
    [QUOTE=Robik;14371607]Just finished building my 27.5 frame with 29 components. Fork is set at 150mm but will try 160 once I have enough rides.
    Robik,
    Donīt use a C C Inline air , I did it and broke it in two pieces after the first ride , Cane Creek offered the DB air CS as a more robust option and it has been great after a while. Cane creek realized inlines are not good for stumpys as our bikes put too much force on the down eyelet area . As Brash said Air CS offers good support and bottom out resistance without any harshness. 210x55
  50. #2050
    Sep 2017
    [QUOTE=tonijou;14378969]
    Quote Originally Posted by Robik View Post
    Robik,
    Thanks for the heads up! I almost pulled the trigger on one off the eBay as the price is too good to pass. Will definitely get an CS.
  51. #2051
    Dec 2018
    You won't regret it Robike, great shocks with a LOT of tuning capability. I have a good baseline tune if you get stuck. Even at 225lb body weight I only require 170psi to maintain 30% sag on the Air CS which is a nice change. The initial stroke is very supple, very similar to a fox X2. But has a more pronounced "notch" in the travel when the air travels through the transfer port. You don't notice it on the trail however.
  52. #2052
    Jun 2013
    Guys, now that you've been ridden longer, what's the feeling? Offset 44 or 51 what's the difference or is it.
  53. #2053
    Sep 2014
    I had a 150mm 51 mm offset Yari on for a month while my stock Rhythm was in for warranty. I noticed the quicker steering with the 51mm offset.(which was fine).. But the added wheelbase and less weight on the front was noticeable. In the end I preferred the 44mm offset.
    Quote Originally Posted by Macharza View Post
  54. #2054
    Jun 2013
    Quote Originally Posted by JJ1408 View Post
    Thanks for reply. That's how I thought things were going to change
  55. #2055
    Oct 2018
    Out of interest, what was wrong with your Rhythm?
  56. #2056
    Oct 2018
    New headset fitted... First ride, problem came back. Everything points to the headset, but to makes things worse the problem comes and goes. The shop thinks it could be the fork if not the headset but it's not like any CSU creak I've heard before, and it's inconsistent.
  57. #2057
    Reputation: User Desactivated's Avatar
    Aug 2019
    Hi,
    I just f*** up my knee, so I'm considering swapping chainring to get some oval stuff so I can keep biking before surgery. Yes I'm lazy and don't wanna remove everything at the moment, do anybody know if the OEM NX chainring is standard (3mm) offset or is it 6mm ?(I'm running 11 speed 11-50 cassette). Please let me know if you know what the specs are, cheers !
  58. #2058
    Jul 2015
    hi all,
    anyone know what the chainline is on the alloy stumpy evo, im changing over to Shimano 12 speed and there's 3 different boost crankset available ...
    ta
  59. #2059
    Sep 2019
    Quote Originally Posted by louf View Post
    hi all,
    ta
    i struggled to find this info but..
    73mm BB shell width
    2.5mm spacer on drive side of MT800 BB
    so
    52mm chainline is what i bought. No issues
    Last edited by blackjack88; 2 Weeks Ago at 07:14 AM. Reason: changed not to be so definitive
  60. #2060
    Jun 2013
    73mm BB shell width
    so
    Good info, thanks
  61. #2061
    Jul 2015
    73mm BB shell width
    so
    thanks 👍
  62. #2062
    Oct 2019
    I have some you can buy if youíre still looking.
  63. #2063
    Jan 2019
    anyone has info on frame weight of s2 carbon vs alloy?
  64. #2064
    Sep 2014
    111
  65. #2065
    Sep 2014
    First time was fork stuck down.
    Now they are sent off for a creaky steer tube. My shop has a loaner fork which is great.
  66. #2066
    Sep 2014
    Take the fork off and wrap the steer tube in a cloth and lightly clamp it horizontal in a vice. Then push the lowers quickly and firmly forward and backward and then try side to side. That will isolate it for you. That will put to rest whether it was the headset or not,
  67. #2067
    boatesfamily9
    Aug 2019
    Hey guys - if anyone is interested we weighed my S3 27.5 comp alloy which is stock and it came in just over 34 lbs.
    Sorry if I missed this on the thread but seems like some of you bought the 27.5 bike and put 29" wheels on it? If you did I'm curious why you would do that instead of buying the 29er?
  68. #2068
    Sep 2017
    Quote Originally Posted by boatesfamily9 View Post
    I bought 27.5 frame for less than 1K in perfect used condition. Had all good parts for 29 build. It came slacker, longer and with higher BB. Win-win?
    PS: I usually swap the frame/bike every year or two, so no big deal
  69. #2069
    boatesfamily9
    Aug 2019
    Cool thanks have fun!
  70. #2070
    Jun 2019
    Good job! IMPORTANT: MRP Progressive Coil Spring
    IMPORTANT UPDATE for all those with a Coil Rear Shock:
    The MRP progressive coil spring is the truth! Just installed it the other day and took it for a test run off the biggest jumps and drops I could find.
    No more having to over spring the bike at 25% sag to prevent harsh bottom outs or prevent the bike from wallowing like crazy under power.
    The Stumpy EVO has only 9.5% Progression in the rear linkage which basically means it is almost completely linear and NOT a suitable match for a coil shock, let alone one with only 140-150mm travel.
    That said, the MRP progressive spring adds 10-15% progression depending on the weight, giving the EVO around 20% progression and since the progression can be felt at just 50% travel with no real pedal kickback it pedals like a dream with much support in berms and off jumps and drops.
    It's a whole NEW BIKE, almost like a short travel Enduro!
  71. #2071
    Dec 2018
    I need to invest in one of these springs but I don't think the rate goes high enough yet. I'm running a 600lb now, and it's great until I case a jump or land to flat. The 650lb solves this but rides higher in the travel and unless I compensate with my fork gives a "stinkbug" rear high stance.
    So a progressive spring that starts at 600lb and ends at 650 would be spot on.
    I'm going to bring both air and coil to NZ for my trip because knowing my luck I'll blow a shock up. But if I'm having too much fun on the jump trails can quickly swap to the air shock.
  72. #2072
    Oct 2018
    Hi everyone. I like to buy SJ EVO Comp Alloy, but can't decide if 27.5 or 29? I've ridden Specialized Status and Cube Sting 29 (it has 140mm travel rear). I'm 176. Looking for S2 frame in both wheel sizes. Bike is going to be used in bike parks and on local trails.
    I think that 29 is the future, but I don't know if I'm ready for that future. I want to learn a lot of gravity stuff (which is easier on 27.5 and I'm not so experienced in it), but I want to participate in local enduro events (which is easier on 29 - more speed + higher BB).
  73. #2073
    Dec 2018
    I did some research yesterday on progressive springs. Which one did you go for? Because the MRP spring physically wont fit in a 210x55 CC DB IL (too long) and the SAR/Eibach ones do not have a high enough spring rate for my purpose.
  74. #2074
    Reputation: Shredmonkey's Avatar
    Jan 2013
    Quote Originally Posted by plow View Post
    Iíll throw in my $.02 and say go 29. Mainly I think it just edges out the 27.5 as the better all around bike and the bb height is already low enough. This was my first 29 and honestly couldnít tell much difference in wheel size after a few rides.
    The only time I notice the 29s as a negative is it feels a little awkward hitting dirt jumper style hits with short transitions, which I donít do all that often anyway so no biggie.
  75. #2075
    Feb 2013
  76. #2076
    Sep 2018
    That's a sweet build, thinking a S2 27.5 frame build with 29" wheels could fit the bill here. Still progressive but not as crazy (shorter chainstays, slightly shorter reach, higher BB, and shorter wheelbase compared to a S3 29).
    Is that BB with the flip chip in high or low? Do you know the HA? Have you tried or do you think you'd be able to run an offset shock bushing for a higher BB and steeper HA?
    Also how is the MRP SXg? Might want to run one of those, at least for any park. No issues with only two ISCG 05 holes and play?
  1. 2019 Specialized Stumpjumper
    By fc in forum California - Norcal
    Last Post: 12-12-2018, 03:28 PM
  2. Specialized Stumpy EVO 2019 to the stores
    By javiergutz in forum Specialized
    Last Post: 07-01-2018, 03:50 PM
  3. 2019 Specialized Stumpjumper
    By fc in forum All Mountain
    Last Post: 07-01-2018, 01:33 PM
  4. Will the 2019 stumpjumper get an overhaul
    By nilbert in forum Specialized
    Last Post: 04-21-2018, 03:27 PM
  5. 2019 Stumpjumper
    By rjcobra in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 04-15-2018, 02:11 PM
Members who have read this thread: 628
