2014 S-Works Epic NDS crank arm loose. Need alternative- Mtbr.com
Results 1 to 1 of 1
    The non drive side crank arm is loosen. I stopped by a shop and they weren't expereinced with the crank but said I'd need a new crank arm. Whether it's warrantied or not I need a replacement crank ASAP so I'm wondering what I can do while I wait to replace this particular arm. I don't have quick access to my dealer.
    Here's the stats from the specs: I'm not sure of the width of the BB. But this is what it says:
    CRANKSET
    S-Works, FACT carbon, 30T X-Sync ring, 104mm BCD spider
    BOTTOM BRACKET
    SRAM, PF30, OS press-in bearings, sealed cartridge
    1. Can I replace this with any BB30 crank or is there something specific I need for the ID of the bearings?
    2. I'm running a 170mm crank and as I may need an emmergency replaccement I'd love to try a 167.5 or 165mm crank. Do I have any options for that that are also 104BCD?
    3. How do I remove this crank? Does anyone have a link to the proper SRAM instructions for this model.
    4. To double check though; is there a way to tighten this arm or is it really finished?
    Sorry I'm on the road overseas and can't upload the video of the arm moving. I'm trying to include a still shot. The arm is bascially loosened and wobbles badly (it's done 16000 miles). The little flange and the 8mm(?) hex there are both already tight, or at least I could not budge them.
    5, if needed, is this arm a part I can replace?
    Here's the link to the still shot if it's working.
    https://photos.google.com/photo/AF1Q...zRUvjs0aALljlY
  1. Replies: 30
    Last Post: 05-01-2015, 06:39 AM
  2. 2014 S-Works Epic vs. 2014 Scott Spark 900 SL
    By OCDirt in forum Specialized
    Last Post: 04-03-2014, 09:30 AM
  3. 2014 Spark 900 SL vs 2014 Specialized S-Works Epic
    By OCDirt in forum Scott Sports
    Last Post: 03-30-2014, 04:38 PM
  4. Replies: 14
    Last Post: 02-25-2014, 05:07 PM
  5. Replies: 8
    Last Post: 01-10-2014, 08:29 PM
