2014 Epic Carbon Comp Internal Dropper Routing?- Mtbr.com
    Reputation: davemk's Avatar
    Jan 2009
    I just purchased a 2014 Epic Carbon Comp and converted it to a 1x10 drivetrain with a ONEup 42t cog. I'm thinking about adding a dropper post, and wanted to know if it is possible to route the cable internally through the front derailleur access. Anyone tried this or know if it is possible?
    "Less yappin' more braapin" - IFHT
    Jan 2009
    Anyone have any idea? I can't be the only one who wanted to do this.
    Dusting Trails
    Reputation: matuchi's Avatar
    Does you bike have an access opening in the bottom? If it does I think it's doable.
    Yes it can be done. The new 2014 S-Works Epic 29 is equipped with the new 35mm IR dropper post...Pick which side you want to run the cable from the bar to the frame, and use the appropriate cable guide that bolts into the top of the downtube to run the cable.
  1. Upgrading to XT Brakes on 2014 Epic Comp Carbon
    By simontonmc in forum Specialized
    Last Post: 07-29-2016, 08:17 PM
  2. Replies: 56
    Last Post: 06-27-2014, 10:16 PM
  3. 2014 Epic Internal routing water leakage?
    By gigabyte772 in forum Specialized
    Last Post: 05-07-2014, 12:02 PM
  4. Internal routing dropper post on stumpy
    By Unforgiving in forum Specialized
    Last Post: 12-03-2013, 08:03 AM
  5. Internal dropper-post routing
    By Sweetwater Jones in forum Beginner's Corner
    Last Post: 11-10-2013, 08:22 PM
