Recommended chain lube for Florida trails?- Mtbr.com
Results 1 to 14 of 14
    Jun 2013
    Still getting used to riding Florida sugar sand. What chain lube is your go-to?
    I was using an all-conditions wet lube at first but that just clogged up the chain with sand. I switched to the Finish Line dry lube but not sure how well it's lubricating plus I go through the stuff quickly and still makes the drivetrain noisy.
    Paraffin wax, which is time consuming and complicated to reapply. I have not seen anything that keeps the chain contamination free in FL including sand. If you do not want to mess with waxing the chain then White Lightning Clean Ride works well, just make sure the chain is stripped of all other products and clean/dry before applying the WL.
    Florida rider here...I use Boeshield T9. Works good, lasts decently long. I put it on after a ride so it can dry overnight. Chain stays pretty clean through the sand.
    Jun 2016
    +1 for WL Clean Ride. I've been using it for several years in FL. Keeps the drive train reasonably clean, is easy and fast to apply, and it's cheap. Downside is that it wears off fairly fast. It's good for about a 100 miles (less if conditions are wet) before it needs to be reapplied.
    Reputation: chadbrochills's Avatar
    Aug 2018
    Central FL rider here, I use Finish Line DRY. Works well.
    2019 Santa Cruz 5010 Carbon C. R Build, in Purple.
    Spank//i9//Deity//Magura//DVO
    The perfessor
    Reputation: mr_chrome's Avatar
    Jan 2005
    - ProLine gold; we have some places here in North GA that are sandy due to the amount of rock in this area and this lube seems to do an excellent job of not picking much of it up.......
    Rigid 29er Ti SS
    KHS Solo One SE 29er
    29er SC Tallboy AL
    Trek FX Sport Carbon 4 Hybrid Bike
    Coffee Drinker
    Reputation: Taildragger's Avatar
    Mar 2005
    I've had great results with this;
    Reputation: LyNx's Avatar
    We have a lot of sand and dry down here, I use the White Lightning Clean Ride as well. Did get some of that Squirt dry lube when we visited Crested Butte in '16, it was very dry and dusty and it worked really well. Only thing with the dry lubes in general is you need to basically apply after every ride, but better than using a wet lube that attracts all that grit and grime to eat your drivetrain.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Jan 2016
    I've had good luck with Prolink.
    Nov 2016
    Rock n Roll Extreme is the best I've found. Apply the night before, wipe the excess before your ride. It'll leave a dry wax-like coating that's very slick and sand won't stick to it.
    out of here
    Nov 2018
    see ya all later!
    May 2019
    S. FL rider here, I used Muc-Off C3 Dry Ceramic Lube.. goes on simply, easy to remove and reapply no build up in dusty setting nor issues on the wet. I haven't experienced any mud yet, though.
    Attached Thumbnails Attached Thumbnails Recommended chain lube for Florida trails?-872_c3_dry_lube_120ml_2.jpg
    2019 Ibis DV9 XX1 Gold | Code RSC | 25.4lbs
    2018 Orbea Loki 27 XX1 Rainbow/Black/Grey | Code RSC | 28.11lbs
    Jun 2013
    After trying a couple of dry lubes, I found that they all sucked. They didn't last long, the drivetrain was noisy, and the chain didn't stay that much cleaner than a wet lube. I went back to Rock n Roll Gold and have been pleased with it.
    Reputation: whitecoyote's Avatar
    Sep 2014
    Quote Originally Posted by matt.s67 View Post
    Plus 1. Works great!
  1. Chain lube question -- lube internals only?
    By DennisF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-21-2012, 11:03 AM
  2. Replies: 11
    Last Post: 09-28-2011, 03:19 PM
  3. What chain lube is recommended?
    By silverwolff in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2008, 08:40 AM
  4. Lube Lube Lube...
    By PimpinD in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 06-15-2008, 05:50 AM
  5. Florida Communities Trust 2008 Florida Forever Funding (for trails)
    By WolverineGator in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 03-01-2008, 02:26 PM
Members who have read this thread: 8
