Quality tires for FL landscape and dirt/sand.- Mtbr.com
Results 1 to 8 of 8
    So I have a post in the 29er forum about the Giant Talon 0. Basically, the people said that I should probably switch out the tires for something better for my terrain.
    I was hoping to get some insight on what has worked best for the FL riders. Granted I do not want to spend a lot and would be even happier if I could switch out the current tires for different ones.
    Here is the link to the other post.
    http://forums.mtbr.com/showthread.php?t=722316
    Thanks all.
    Where exactly do you ride most often?
    Quote Originally Posted by Flboy View Post
    Carter Road in Lakeland. I will be going to Santos too, but not nearly as often.
    XXIX
    Reputation: GatorB's Avatar
    Just swap out your front tire for a Kenda Nevegal and keep the small block eight on the rear. You could probably swap out that sm 8 for a Nevegal on the tire swap thread and will not cost you a dime. Make sure you get your tire pressure dialed before you start swapping tires out. Those small block 8's have a lot of grip at the right pressure. I ride all the trails in central Florida on a 29er and and I like the Nevegal on the front and a Hutch python on the rear.
    14' Vassago VerHauen
    [URL="https://m.facebook.com/pages/Spruce-Creek-Mtb-Trail/572082766223954"]
    Quote Originally Posted by GatorB View Post
    Thanks. I will also talk to my LBS and see if they can do something like this.
    I agree with Gator the small blocks are awesome tires if used in the right pressure range. I have mine set at 50psi btw.
    2011 Cannondale Trail SL3
    2012 Santa Cruz Tallboy DXC
    Quote Originally Posted by ThierryR. View Post
    That is what my LBS said too. I was going to have them switched out, but probably not now.
    I am running SB8s tubleless at 27psi front and 30psi rear
  1. Loose sand/dirt trails..Change tires or go slower...
    By jbl_91762 in forum Beginner's Corner
    Last Post: 12-31-2012, 11:25 PM
  2. Calling all BikePark/Dirt Jump builders! (Free landscape materials)
    By subliminalshiver in forum Colorado - Front Range
    Last Post: 07-09-2010, 09:31 PM
  3. Good set of tires for loose dirt/sand (Santa Monica)
    By jman536 in forum Wheels and Tires
    Last Post: 09-15-2008, 01:06 AM
  4. Kauai red dirt and beach sand
    By PCinSC in forum Riding Passion
    Last Post: 09-05-2008, 06:38 AM
  5. Sand Tires for XC work? X-Post Tires
    By JmZ in forum Ventana
    Last Post: 09-22-2005, 05:27 AM
