Zion EBB - Bottom Bracket Options- Mtbr.com
    Mar 2005
    I've just ordered a Zion 853 EBB frame, decided that the custom frame at three times the price wasnt worth it ... only advantages were Fit, No v-brake boses and no deraileur hanger.
    Anyways,
    Can the Zion's EBB shell take any style of cranks and bb? I'd like to go to a non-shimano external bearing design (possibly truvativ or race face I think). I'm not building the frame up for a while, so I can wait for more external bearing options to come out if there arent many now.
    Also, can someone confirm that the head tube is prefaced and just needs the headset pressed into the frame?
    Thanks,
    -Chris
    PS Planned build is
    Chris King disc hubs with DT competition spokes on mavic 717 rims
    tompson seat post
    selle italia slr steel seat (the 160g one)
    Chris King headset
    2001 Z1 Bomber forks
    Easton alloy bars and stem
    Cranks ?
    BB ?
    Chain ?
    Brakes - deore 525
    A mixture of old and new parts.
    Chillin the Most
    Warning
    be careful, check that you have enough tire clearence before you build your bike. On my 19" frame I barely had any clearence in the stays with a 2.1 (Kenda Nev) dry, and even with a 1.95 (kenda nev) the mud here in Ohio was still causing issues. Called Jenson and was told since the bike was built and ridden TS and have fun selling it on Ebay. Needless to say when my Surly 1x1 gets built, this is going on Ebay for $150.
    As for the cranks, you can mount whatever you like.
    Guys at my shop that installed my headset didn't mention my ht needing facing, I can't remember 100% but is should be OK, but check to be sure.
    BTW, the EEB frame does come with brake bosses (non removable) and hanger (again non removable, unless you feel like sawing away at your frame).
    Good luck I hope it works for you. Other than the tire clearence issue, it's a great frame.
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    My Zion
    Any crank/bb should work. I squeezed a Kenda Kinetics 2.35 in the rear, but its tight, and I live in dry utah. I had the shop face the HT when they installed my king headset just in case. Enjoy the frame, I love mine so far. Post pics when you get 'er built
    jmw
    jmw is offline
    Reputation: jmw's Avatar
    Feb 2005
    any STD BB will work, although I recommend a square taper.
    I love my Zion - great bike for the $$...I've got a 2.25 Trailbear in the rear and clears OK. Depending on the size, clearance gets iffy on the larger sizes I think. Mine is a 17".
  1. monocog bottom bracket question...
    By homestar in forum Singlespeed
    Last Post: 11-15-2005, 08:59 PM
  2. which bottom bracket size?
    By Jaker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-04-2005, 11:04 AM
  3. bottom bracket type??
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2004, 10:06 AM
  4. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  5. Help with bottom bracket
    By DoothaBartman in forum General Discussion
    Last Post: 04-10-2004, 02:44 PM
