Zero offset DM oval chainring for Hollowgram?- Mtbr.com
Results 1 to 2 of 2
    Given all the reports of carbon crank failures, I think the Cannondale Hollowgrams should be more desirable, especially for singlespeed use. Love the idea of direct mount / spiderless rings since I've had too many broken chainring bolts (aluminum of course, not steel). Also ran into varying chain tension and chain retention issues due to out of round spider/ring combos. Once it's all dialed it's usually fine but I still think DM is a great idea.
    The problem is offset is fixed and there are way too many damn spline patterns to allow mixing & matching.
    122 mm spindles are easy to source now and yield a better (for me) Q-factor of about 160 mm vs. 170 mm typical (ow my knees). Unfortunately nobody makes a DM chainring with zero offset needed for 48 mm chainline. Seems like such a simple and obvious great combination for singlespeed.
    Maybe if more people figure this out and show support a company like Absolute Black will step up and fill the void!
    Edited original post on real computer.
  1. Oval Chainring, Absolute Black Vs Wolftooth
    By inter in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-31-2018, 06:02 PM
  2. Absolute Black Oval Chainring
    By Lindahl in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-04-2018, 06:00 PM
  3. Absolute black oval chainring on Raceface Cinch crank installation
    By gorgebiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-22-2016, 01:38 AM
  4. Absolute Black Oval Chainring - my review
    By GuruAtma in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-05-2015, 10:11 PM
  5. Replies: 6
    Last Post: 02-08-2015, 12:46 PM
