Your favorite chain?- Mtbr.com
Results 1 to 32 of 32
    Reputation: Hairnet's Avatar
    Jul 2013
    I am pretty much a noob to mountain biking but I have been doing well on my SS. Coming from road cycling and years of riding fixed gear I have found the KMC K710 and K710SL to be excellent low-cost chains. I just switched out the chain that was on the bike(used) with a K710 and I hope it will be just as smooth and quiet off road as it is on road. How about you all?
    Running the KMC Z610 that came on my Kona. Will be switching to an orange KMC Z410 today. Matches lettering on bike as well as hubs, cables etc.
    It is a 1/8 chain but have been advised its OK to use in place of 3/32. Might be a bit of chatter but not a problem, so i've been told.
    I guess I'll find out later today.
    What's "social pace?"
    I just ran a K710 for three years with no maintenance at all. Finally replaced it with a K710SL.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I've used Shimano's CN7701 for years (9 speed size cogs and chainwheels). Works great lasts long. Last time I needed a chain, CN7701 was outrageusly expensive at the LBS I dropped by at, so I picked up a KMC X9.93, instead. It is supposed to be "Hi-Performance, Extremely Durable". Looks promising, so far.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Sram PC870s are super cheap and work as intended. Never broken one and they arent prone to rusting. 890s have a more comprehensive nickel coating, but I have never tried them.
    Stay away from cheap chains like the PC1 and KMC410. They stretch very quickly.
    Raised in a Chicken-Coop by Chickens
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    I use Sram 870/890 chains on all my bikes, 2 geared and 2 SS
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by perttime View Post
    I've also used XT and XTR chains most often on my geared 9-speeds because they tend to last longer. A friend suggested the KMC X9.93 so I installed one on a new hard tail build. Seems to be fine though I find that it requires a lube more often (just about every ride) compared to the Shimano chains. Curious to see if I get similar miles out of it...
    On my single speed I run inexpensive Nashbar 8-speed chains (mostly on Chris King cogs with Blackspire and MRP rings).
    I keep tabs on chain wear with a Park CC-2 chain checker and now also a Shimano CL41 chain wear indicator tool.
    【ツ】 eDub 【ツ】
    Jul 2013
    Quote Originally Posted by edubfromktown View Post
    My K710SL measured 1.0 right out of the box
    Reputation: jetboy23's Avatar
    Quote Originally Posted by drjay9051 View Post
    If your drivetrain is 3/32, why would you run a 1/8 chain thats the same strength as the 3/32 you are replacing? That "slop" from the chain being wider than the rings will increase wear. Too many strong 3/32 chains to pick from that are inexpensive. Z610, K810, x8.93, 851, are all great wearing chains and can be had for <$15.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Pc-971.
    Spp
    Rigid.
    Cif
    Cif is offline
    Reputation: Cif's Avatar
    Jan 2013
    Re: Your favorite chain?
    I still use my KMC Z610 that was on the bike when I bought it. 1500k since and it starts making a ticking noise. Will replace with the same, since they are super cheap.
    Reputation: Andy R's Avatar
    Nov 2008
    Quote Originally Posted by Cif View Post
    And super good.......
    one chain loop
    Reputation: fishcreek's Avatar
    stick with what you have that works for you. personally, i like my kmc k810.
    everything sucks but my vacuum cleaner.
    Quote Originally Posted by jetboy23 View Post
    Find me a 3/32 in orange.
    Jan 2011
    I like my HKK 40, aqua series chain.
    I did some research and think it may be the last chain I will ever need.
    My drivetrain is based on custom parts to run #40 style roller chains if you really want your chain talk to your local machine shop and/or send me a PM. The parts are not very hard to make. Most machine shops will be able to fabricate what you need although it will be expensive.
    shop guy 20 years, singlespeed ride/race over 12 years. sram pc 850. cheap, durable. no brainer.
    rog
    Reputation: Harry Mackenzie's Avatar
    I have SRAM PC850 on 3 of my bikes. SS trail bike, SS pavement beater, and a 3x8 trail bike. They seem to be holding up fine but each chain only has around 800 miles each so time will tell. My Monocog trail bike has been getting a lot of trail love and I have had to adjust the tension a few times in the past month due to what I think is chain stretching.
    if you run surly stainless steel chainrings and cogs, everything lasts longer with less frequent tensioning. got 6 full seasons of riding year round and racing summers out of just 1 34t surly ring and an 18t surly cog. replaced my 850 chains twice a year at less than 10 bucks a piece (cost). cheap easy breezy riding. the ring and cog live on, btw. sold them with the bike.
    rog
    Reputation: asphaltdude's Avatar
    That's probably the quick link, the pins on that link wear out faster than those on the rest of the chain.
    Major flaw IMO.
    Ride more!
    Cif
    Cif is offline
    Jan 2013
    Nope no quick link on my bike. Chain ticks al over. Probably just stretch out and needs replacing
    Reputation: shiggy's Avatar
    Dec 1998
    Wippermann Whitestar 108. Best singlespeed chain I have put on a bike, in every respect.
    mtbtires.com
    COTA member
    Reputation: Dry Side's Avatar
    Happy with a Gusset Badger SS-Pro Chain 3/32" on my Niner A9C SS.
    local trails rider
    Aug 2005
    Take a close look at your chainring and cog too. Eventually, they wear out and can develop a shape where the chain sticks before releasing from each tooth.
    Cif
    Cif is offline
    Jan 2013
    Checked chainring a couple of weeks ago, but will check again.
    The ticking only occurs when applying serious power. At normal power everything is nice and quiet. Does that make sense?
    local trails rider
    Aug 2005
    Under load, tensions are higher - between chain and chainring, in pedal bearings, in BB bearings, .... It can be the chain but don't exclude other possibilities.
    Quote Originally Posted by newmarketrog View Post
    rog
    I'm running Surly ring and cog with an 850 also. How do you know when the chain needs replacement? I don't really want to wait until it snaps.
    Jan 2011
    Quote Originally Posted by AnonymouseTech View Post
    Inspect your chain...
    The "KO" is for when the chain is knocked out.....
    My advice is that you simply buy two chains then when it stretches to the point where it is loose on the drive train you can put the second chain on. After the second chain stretches you can clean both chains, adjust tension, and then mount the shorter of the two chains.
    It is also a good idea to measure the chains when you clean them. Park sells a chain measurement gauge so you will know when to replace. You can push a chain a good bit beyond the wear limits but it starts to damage the rings and cogs. If you run the chain too long it will start cracking then fail soon afterwards.
    Also, the SRAM 850 and 870 chains are really quite bad for single speed usage. These chains seem to be designed to be loose fitting and wear quickly. If you measure a brand new 870 chain and compare it with a KMC you will find it starts out longer. I think SRAM must do this on purpose. It might help shifting but it hurts wear.
    SRAM also uses a modified roller chain design that does not include bushings. The SRAM design seems to be weaker then other chains.
    More really good information about chains is on Sheldon Brown's page.
    Chain Maintenance
    psycho cyclo addict
    Quote Originally Posted by shiggy View Post
    Ima check that out; thanks Shiggy.
    Reputation: AlexCuse's Avatar
    I run sram 8 speed, highest number I can get. I think LBS usually has 850's or 870's for 20 bucks or so.
    Recently had a white industries crank put on when I was on vacation, and they put a PC1 chain on it I guess I'm glad they were trying to save me money, but still kinda unimpressed, especially because the cog and chainring are 3/32. Pedals smooth enough but I don't like how much it moves back and forth. While be switching back to an 8 speed as soon as I can.
    Yeah I only carry cans cause I'm a weight weenie.
    Sep 2013
    Is the KMC x9 there standard 9 speed chain and if so do you recommend a non S.S. chain for S.S. ?? I love the idea of using a missing link...Thx
    Sep 2013
    Rog...Do you use the power link with your pc 850 ??
    Snail. A fast one.
    Reputation: Brisk Snail's Avatar
    Oct 2013
    I've bought 3 Miche Pista Track chains recently. The first impression - they are really cool. Light, nickel-plated, cheap and "tight", which means pins are more narrow, and plates & rollers are very close to each other and there is no space to collect dirt. The surface of the plates is also smooth (unlike some ss KMC chains, which surface is more like moon). On KMC K710, both regular and halflink, there is plenty of space between rollers and plates, so, after a puddle or a sand spot, the chain just keeps crunching for hours and hours. Plus all the lube is constantly leaking out. No such problems with Miche.
    Is it durable? Well, we will see. So far no significant wear is detected.
    P.S. I use On-one stainless chainring, shimano DXR cog and 3 Miche chains. I run one chain, then, when it needs lubricating, I change it for the second one, then for the third and so on. Every 3 changes I flip the cog to let the both sides wear equally.
  1. Chain wrapping back around crank sprocket catching on chain stay what to do?
    By Thall36 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-05-2013, 08:53 PM
  2. Replies: 4
    Last Post: 03-14-2013, 05:23 AM
  3. Chain skipping- new rear derailer, cable chain and cassette already in place
    By Master Obiwan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2012, 08:06 AM
  4. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  5. What's your favorite chain lube?
    By nevermiss in forum General Discussion
    Last Post: 05-02-2011, 06:27 PM
