Are you happy with your non specific SS Frame?- Mtbr.com
Results 1 to 9 of 9
    Are the chain-tensioners(which ones?) working for you or you wished you would have gone with a SS specific frame?
    nothing cleaner than tensioner-less, no der. hanger, no ebb, no track ends.
    eccentric hub or bb, then hit that hanger with the dremel and file.
    If steel is real then aluminium is supercallafragiliniun!
    SSOD
    Reputation: Crosstown Stew's Avatar
    I'm running a frame with horizontals now but have had tensioners in the past on other frames. If I were to do a frame without track ends I would probably look for one with paragon sliders. If you are wanting to stay with verticals then an ebb or a eccentric hub probably be only choices without dirtying it up with a der style chain tensioner.
    Quote Originally Posted by Crosstown Stew
    But in order for me to use an EBB I have to get a frame with an oversized BB shell right?
    Dive Bomber
    Reputation: jackspade's Avatar
    Mine is semi horizontal drop-out but still use tensioner.
    It's just that my rear hub/axle a little bit loose which make my chain tension loose.
    Out spokin'
    Dec 1999
    Quote Originally Posted by Firemedix911
    Forward Components offer an EBB that fits in a standard BB shell.
    http://www.forwardcycle.com/
    --sParty
    disciplesofdirt.org
    --sParty
    Yeah I've been looking at it after I posted my question. Search function does help. LOL. From what I saw on the website of FC it will fit my XT crankset right?
    Out spokin'
    Dec 1999
    Here's a list of compatible cranksets.
    http://www.forwardcycle.com/compatible_cranksets.html
    --sParty
    disciplesofdirt.org
    Sweet man My xt-770 are there. Take care. Thanks.
