yes, I'm a ss wanna-be- Mtbr.com
Results 1 to 6 of 6
    surly inbred
    Reputation: TroutBum's Avatar
    posted this over on the general forum..
    over here...
    as a side bar, I took apart an old Xt ('98 'ish) crankset tonight to remove the small & large rings, but found the bolt & bushings would not seat tightly on the 32 tooth afterwards.. are there spacers available? what do folks use to set up the front ring?
    thanks,
    ~mud
    Ride More
    You could get new chain ring bolts for a couple of bucks at your LBS. Another option is to put a bash ring on the crank. This would take up the space that the big ring normaly takes up. Sinec you want to save money, I would stick with the bolts.
    Andrew
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    Quote Originally Posted by muddog999
    over here...
    thanks,
    ~mud
    The stock c-ring bolts had three layers to hold together: big ring, spider arm, middle ring. Now that you've removed the big ring you've removed a layer, so the bolts are too long. You need short bolts such as these single bolts:
    http://www.webcyclery.com/home.php?cat=302
    surly inbred
    Quote Originally Posted by Nat
    ... You need short bolts such as these single bolts:
    Thank you kind sirs...
    wasn't sure what was available aftermarket.
    Now if I could only figure out this horizontal vs vertical dropout bit... I just don't see the diff if there's no change in "effective" chain length. Why can't I just swing a shortened chain around a 32-16 (with spacers) with no concerns? Am I missing something?
    Reputation: Kennetht638's Avatar
    If you really want to save some money (and perhaps some time), you could do like I did and file away at the existing too-long chainring bolts until they're no longer too long.
    The issue with chain length has to do with the fact that you can only add/remove an inch of chain at a time. This is not very fine adjustability, so most gear ratios will result in too loose of a chain. Then, once you find that perfect ratio, you can't just add/subtract 2 teeth (one inch) at a time, because the diameters of the cogs change non-linearly with the number of teeth (circumference), giving the chain slightly longer/shorter runs.
    surly inbred
    My first thought was to head for the grinder... I just get nervous about botching threads.
    so I found this link tonight... should solve the single cog issue, but if I may... what determines the right chain length, ie... need for a tensioner?
    spacers
  1. Emerging SS Perspective
    By waltaz in forum Arizona
    Last Post: 01-15-2005, 07:40 AM
  2. Singlespeed: More or less efficient?
    By grumpstumper in forum General Discussion
    Last Post: 01-13-2005, 01:01 PM
  3. ss fun at the tourne
    By mergs in forum New York - New Jersey
    Last Post: 11-29-2004, 09:58 PM
  4. Is SS more my style?
    By Hardline in forum Singlespeed
    Last Post: 08-21-2004, 10:33 PM
  5. to SS or not? that is the question
    By Nimai in forum Singlespeed
    Last Post: 04-28-2004, 11:46 AM
