    Reputation: Guital2's Avatar
    Feb 2005
    Yay! perfect Tension
    Well I am putting my SS Zion(non ebb, ebay bike) together and got perfect tension with a salsa 36 CR and a shimano 18 rear cog, without the use of a half link.... Lucky me....
    Got to build the wheels tomarrow, I am hopin to have it rideable by Wednesday and ill post some pics, It will weigh in at about 22.5lbs when finished.....
    When You Connect...
    the two ends of the chain, are you using a power link? I have found that if I try to use a power link to connect the chain, the fact that the chain needs to be slightly longer (to accomodate the pins sliding to lock in the P-Link) the chain ends up being too long for perfect tension. I have not tried to break and re-join the chain sans the powerlink and am wondering if this is the key?
    MTBDad
    MCM #47.867
    "Freedom has a scent like the top of a newborn baby's head" - Bono
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    The chain doesn't need to be longer in order to use a Powerlink. Simply connect the chain while the rear wheel is unmounted, then wrap the chain around the chainring the front and the cog in the rear and remount the wheel to establish tension.
    Feb 2005
    I didnt use the powerlink......all standard bmx izumi chain....I did find however that using an SS cog that came with my gusset set loosened up the tension a bit, it is the same tooth count too.....weird.
    play around with it a bit, try a half link if you need....
  1. using MRP to tension chain
    By MD Bullit in forum Singlespeed
    Last Post: 01-19-2005, 08:25 PM
  2. What are the signs of too high a spoke tension?
    By Ratt in forum Wheels and Tires
    Last Post: 09-04-2004, 02:30 PM
  3. Proper spoke tension?
    By Spyky in forum Wheels and Tires
    Last Post: 06-15-2004, 09:48 AM
  4. Suggestions for amount of tension
    By Yellowstone Yeti in forum Wheels and Tires
    Last Post: 05-05-2004, 09:03 AM
  5. Spoke Tension specs for various rims?...
    By Ricko in forum Wheels and Tires
    Last Post: 02-04-2004, 06:14 PM
