Yall seen this yet? New chain tention options for vertical dropouts.- Mtbr.com
Results 1 to 21 of 21
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Interesting, but I dont think i would try it.
    Fixed Gear Fixie RoadToPista track dropout adaptor Road2Pista | eBay
    " width="549">
    This was seen on the fixed gear/ss forum of RBR.
    Raised in a Chicken-Coop by Chickens
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    That has fail ingrained in its DNA.
    Reputation: Brewtality's Avatar
    Quote Originally Posted by AZ.MTNS View Post
    No kidding
    Its all Shits and Giggles until somebody Giggles and Shits
    one chain loop
    Reputation: fishcreek's Avatar
    bahahaha.. i couldn't agree more, total failure on all aspect.
    though, i give him props from trying and a bit of creativity but it just won't cut it.
    a smart man learns from his mistakes, a genius learns from the mistakes of others.
    everything sucks but my vacuum cleaner.
    Reputation: rlb81's Avatar
    There is no better way to put it
    Bro Mountainbiker
    May 2010
    I think it **Might** work if there was an ovalish protrusion that stuck into the vertical drops to keep it from rotating. But I dont believe this would work as is.
    Jacob 34:19
    Reputation: JAKEtheDOG's Avatar
    Fixie only I'm guessing. How on Earth would you get your brakes to line up?
    Interesting to analyze for a minute.
    It would steepen the geometry of any bike it is put on.
    With seperate pieces for right and left drop outs, it would be a pain to get the parts all lined up properly. Seems like you would be chasing an out of alignment wheel all the time.
    The bolt hole for the original drop out could have been utilized to strengthen and support the bracket against rotation, but it was ignored.
    So much fail here
    Dinner for wolves
    Reputation: buddhak's Avatar
    I guess hub width would get jammed the fcuk up as well. Turbo fail.
    Responds to gravity
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    The best part of this thread:
    Quote Originally Posted by Sheepo5669 View Post
    ovalish protrusion
    Out spokin'
    Dec 1999
    I think it would work on a FS dinglespeed.
    --sParty
    disciplesofdirt.org
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by buddhak View Post
    No way dude! Easy fix. Just put one track end on the other side of the dropout. Dish the wheel accordingly. Problem solved!!!!
    Dinner for wolves
    You may have something there, sheep boy. Provided the spoke shoulders clear. I bet the non drive side makes the drive side arrangement look like the engine bay of a Porsche.
    Responds to gravity
    So chain line or brake alignment doesn't matter?
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by Brewtality View Post
    Brakes only slow you down. And chain lines are no better than chain gangs.
    Bro Mountainbiker
    May 2010
    BTW, I am not advocating. That product is gay. Yes, I said gay.
    Reputation: itsdoable's Avatar
    Not that different than how a WI eccentric Eno stays put, except the offset is larger, resulting in larger forces. However, on the pictured bike, the track-mount is butted up against the weld bead on the chain-stay, so I suspect that particular setup will work fine.
    Steeper head angle - that's what you want between a track bike vs road bike (as mentioned in the ad).
    Wheel spacing - how hard is it to re-space the axle - you are hacking the bike anyways. Just use a 130mm hub if your bike is 135mm, or a 126mm hub if your frame is 130mm.
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    The ad says it's designed to use a 120mm track hub on a 130mm road frame. It still looks hella sketch though. Maybe if it was on a prettier bike I would reconsider, but I guess that's not the point of "fixing" a perfectly good road bike.
    Sometimes, I question the value of my content.
    Reputation: Sage of the Sage's Avatar
    Wouldn't want to be around for it to fail at speed... ouch!
    Salsa Timberjack SS
    -Gears give me headaches
    Dec 2010
    I could see how that would be a complete failure on the rear because of the forces of the chain, but I would totally run those b!tches up front
    Reputation: jtrops's Avatar
    After you get them glued on with some 20 ton epoxy, and tigten the grade 8 hardware to 100 newton meters it probably won't fail quickly. So, at least you'd notice the slack in your chain before you fly over the handlebars.
  1. Newbie question: vertical dropouts & chain tensioner
    By decipher in forum Internal Gear Hubs
    Last Post: 10-17-2010, 06:26 PM
  2. chain tention with horizontal dropouts
    By Prem in forum Singlespeed
    Last Post: 02-19-2008, 10:40 AM
  3. Replies: 5
    Last Post: 09-04-2007, 05:03 AM
  4. Replies: 0
    Last Post: 06-28-2006, 01:59 AM
  5. Vertical Dropouts and Chain Tension?
    By erkstone in forum Singlespeed
    Last Post: 08-17-2005, 05:04 AM
