XTR crank mod- Mtbr.com
Results 1 to 7 of 7
Thread: XTR crank mod
    Feb 2015
    XTR crank mod
    Getting ready to hack up my 960 crankset for my SS juice project. I've read some of the threads and feel okay about chopping off the outer tabs.
    Any other tips or tricks?
    Im going to polish them up too. Ideas on a clear over the polished aluminum?
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    Its just a lot of elbow grease to get a really good finish. I went thru grades of paper until finishing with 2000 grit and then polishing compound.
    I didn't bother with clearcoat of any kind. When they dulled it was another rub down with polishing compound and they came up pretty good.
    https://fcdn.mtbr.com/attachments/si...4pb5286694.jpg
    Attached Thumbnails Attached Thumbnails XTR crank mod-847853d1384823197-jeff-jones-960-xtr-p4pb5286694.jpg
    Feb 2015
    Sounds good. I used a wire wheel to scuff the anodizing off--they are just a dull brushed look right now--figure I can slowly polish them though.
    Those look good!
    Thanks.. getting the mirror finish took work but IMO totally worth it for the satisfaction.
    Feb 2015
    have a little pitting in the crank faces so I'm going to have to take a litle more to sand those out
    but so far so good!
    Mine had scratches and pitting too, some of the love bites just wont come out
    Feb 2015
    haha yep
    I'm going to get what i can though
  1. Replies: 28
    Last Post: 02-02-2015, 09:24 PM
  2. Can I replace 105 compact crank set 50-34 with Shimano SLX M675 10-Speed 38/24 Crank?
    By wheelinthai in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-27-2013, 11:25 AM
  3. should i spend the extra $100 and get the xt deore 2x10 crank over the sram x7 crank
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2012, 11:27 AM
  4. Replies: 1
    Last Post: 03-11-2012, 06:18 AM
  5. loose crank, rounded taper..bottom-bracket & crank damaged?
    By chimpanzee00 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2012, 03:21 PM
