XD Driver SingleSpeed Options?- Mtbr.com
Results 1 to 24 of 24
    A Man Of The Truth
    Reputation: fellsbiker's Avatar
    New question here. XD Driver SingleSpeed Options?
    I always convert my bike to a single speed before I go downhilling. It's about a 2.4:1 gear ratio, and that's plenty good enough for me, i'm not trying to win any races, just have fun. It's really nice having all that less metal bouncing around. I have a single speed chain, cog, spacer kit and tensioner I keep in a box. Its a pretty quick swap over.
    But not any more! I finally got rid of my ancient azonic outlaw rims, and got some custom made ones that use an XD driver and SRAM 11 speed cassette. The new drivetrain works great, but I still would really like to go back to SS for the lift service. It would be very easy for someone to make a single speed adapter for the XD, but I haven't been able to find any that already exist.
    Do I have any options or am I S.O.L.?
    Somehow I don't have a single picture of my bike in "single speed mode".
    Check out my Mountain Bike Keychains on eBay
    OOOOOOOh Gee Are Eee
    Reputation: Ogre's Avatar
    Feb 2005
    I looked around a while ago and came up empty. If someone makes one I'd love to hear about it
    Reputation: cstem's Avatar
    Does you hub model have a SS driver option? It would add ten minutes at most to your swaps.
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
    Feb 2016
    Unfortunately, there isn't an easy swap option with the XD driver hubshell. Fastest viable option would be having a separate rear wheel with either a single speed specific hub or a hub using the 10 speed drive shell.
    SIR 9 SS
    Fatboy
    Apr 2005
    I purchased I9's on a huge discount - because they came with an XD driver. I too wanted to go SS. So, the search began..... and I too came up empty handed. I even thought of starting a company to make an XD compatible single speed conversion kit (however, I have no machining skills whatsoever so no new company here...). So, I ordered the Shimano compatible hub, swapped out all the pawls and springs and seals, and boom! now we can use any of the SS kits out there. Speaking of kits, I highly recommend the Surly spacer kit. It is of the highest quality. Also, the absolute black cog is delicious.
    Feb 2010
    Quote Originally Posted by cstem View Post
    This won't work. The SS specific drivers are shorter and the hub flanges are wider. Simply putting an SS driver on a hub intended for a geared driver will result in a wheel where you can't get the chainline correct.
    If you're using a DT Swiss rear hub, get an extra set of end caps and the Shimano 9/10 speed driver. Put the SS cog and spacers on the Shimano driver with the extra drive side cap. When you want to convert to SS, pull the XD driver and cap off the hub, put the Shimano driver and cap on, seat the cap, and install the wheel again. /soup
    Reputation: bikeny's Avatar
    What hub do you have? Most hubs have a standard cassette freehub option. You can just buy one of those and do as solo-X suggests. It should be an even easier and quicker changeover than before.
    Feb 2010
    you could probably just play with your limit screws to keep the derailleur in one place (and then remove your shifter to remove any additional temptation )
    Reputation: Jack Burns's Avatar
    Quote Originally Posted by dejock View Post
    dejock,
    Dude, I think you missed the OP's application, whose part-time objective is to ride lift assisted DH without the need for a rear derailleur.
    I think that's a brilliant application! If I shuttled DH, that's what I would do! It's a great idea.
    What brought me here, is that I was wondering if an XD driver hub could be single-speeded. The answer is: no. Unless you can change the driver on the model of hub you have.
    Pity.
    I'm surprised the OP didn't research that before buying the nice wheelset. I need to learn a lot more about the XD driver and how it differs from the Shimano HG system myself.
    The old cassette HG system makes a reliable SS hub.
    I am looking for a single-speedable built bike with certain attributes for my XC activities. The more I resolve my objectives for the build, the more it looks like i will have to go al a carte all the way, or buy a geared bike and change a lot of parts.
    Also surprised some machining wizards at a company like Wheels MFG, Paul, White Industries, or Chris King haven't come forward with something yet. Am I missing something here?
    A Man Of The Truth
    Quote Originally Posted by Jack Burns View Post
    I actually built up custom wheels, and getting the XD drivers so I could run a 10-42 (and hopefully at some point, a 9-46) cassette is far more important than being able to do a singlespeed swap for the handful of days I go to highland. Still would be nice though.
    There is a Single Speed XD driver!
    Quote Originally Posted by fellsbiker View Post
    Wow, I just read the article, and the product, lists at nearly $80, actually takes cassette single speeding to a new level! Stoked to learn about this.
    Here's a quote from the article at the conclusion:
    "Once all of the bolts are tight, the cog is rock solid and there’s no way for it to dig into the freehub body like stamped cogs tend to do on aluminum Shimano freehubs. Compatible with any 6 bolt cogs, if you need a size other than 18 or 20, Problem Solvers offers them in 16-22t. In this case I opted for a 32 – 20..."
    The effect of stamped cogs and certain cassettes on Shimano freehubs has been a let down in existence for decades.
    Link to the manufacturer's site:
    Problem Solvers
    Hey, wait.
    I was thinking how the heck are you running DH single speed on FS without a chain tensioner?
    Unless your on a hard tail, or are using a certain type of chainring chain keeper, that is.
    For XC use I cannot abide spring chain tension devices on my SS bikes.
    May 2005
    The OP is using a tensioner.
    Reputation: Legbacon's Avatar
    https://nsmb.com/articles/true-preci...r-clutch-hubs/
    He is using a SS setup that True Precision is testing.
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    Quote Originally Posted by Travis Bickle View Post
    Wow that's an impressive product review. Both the review and the product are great. Thanks for sharing these Travis.
    On one of my SSs I have one of the old Shimano silent hubs. I would have look up what model they are. They aren't high-end at all. However I do absolutely enjoy the silence of the hub.
    Whenever I get on my other SS with the White Industries freewheel, I notice the sound immediately. That sound is not annoying. It sounds the way a bike should.
    But a silent hub is golden.
    Maybe that's why the True Precision hub is anodized that color?
    Sent from my LG-H910 using Tapatalk
    Reputation: brent701's Avatar
    Sep 2012
    I just run 10 speed hubs. I can switch rims and drive trains with nearly all my bikes that way.
    Too Many .
    Quote Originally Posted by brent701 View Post
    Does that mean you are using different end caps then?
    Kind of related, I saw that Surly's Gnot Boost allows pretty much universal backwards compatibility.
    Also, I just noticed I was missing the point about the True Precision hub, and using a chain tensioner on the FS above.
    All good anyway. Just keep riding.
    Sep 2012
    my Trek Procal is 15x110/12x148 XTR build
    my Trek Stache 9.6 15x110/12x148 Sram GX build XD hub
    My Vassago Mooseknuckle I had built with 15x110/12x148 Nox rims laced to I9 hubs 10 speed driver.
    I found a sec set of Stache 9.6 rims for a good price. Came with a XD driver. I got a 10 speed driver for that rear hub from Trek, was like 20 bucks.
    So I can change all my rims out just no on the stache which I have no reasons to anyway.
    I can run my Niner Carbon rims on my Vassago as a SS, I can run them on my Procal. I run my Nox rims on my Procal with the I9 hubs fr racing. and my SS is currently plus'd SS
    I love the options I have now going all 10 speed drivers. over my last SS driver on my old OpTi Vassago I had built.
    Too Many .
    Phew!
    That's awesome. Live long and prosper indeed.
    I slept through the whole 10 speed era.
    Sep 2012
    Phew!
    LMAO.
    I just ride, kill my legs for a little while and repeat the next day
    More enjoyable on my SS though
    Too Many .
    How about this:
    Problem Solvers
    Quote Originally Posted by jbell View Post
    How about this:
    Problem Solvers
    Yep. Works great! Easy to install and plenty of spacers to dial in the chain line.
    Reputation: bncrshr77's Avatar
    New to singlespeed and I'm interested in seting up my Mooseknuckle!
    I'm looking at the problem solvers zinger in the rear and a Wolftooth dropstop boost 30 or 32 ring up front.
    I'm reading all kinds of different advice on what chain would be best for this setup? Any advice?
  1. Replies: 3
    Last Post: 10-09-2014, 01:43 PM
  2. Singlespeed 650b Options - Sub $1k
    By tychoseven in forum 27.5
    Last Post: 10-09-2013, 07:54 PM
  3. Driver options for Two XM-L, preferably 3-mode, 3000mah max?
    By y0bailey in forum Lights DIY - Do It Yourself
    Last Post: 09-21-2012, 01:30 AM
  4. Hardtail singlespeed options?
    By phsycle in forum All Mountain
    Last Post: 02-16-2012, 02:24 PM
  5. What singlespeed crank options are there?
    By Spikes in forum Fat bikes
    Last Post: 11-14-2011, 04:47 AM
Members who have read this thread: 39
