X-Post - Why Am I Breaking Things?- Mtbr.com
Results 1 to 22 of 22
    Ouch, I am hot!
    Reputation: Dirdir's Avatar
    I just want to know why.
    So, take a look at the pictures and tell me what the **** happened and why? I am getting tired of breaking things. LX cranks and Boone chainring. Why. why, why? The Horror...The Horror...
    I AM JUST A JERK
    Retrograde Customs
    Reputation: dansjustchillin's Avatar
    Damn
    how exactly does one do that?
    Retrograde Customs
    Reputation: ionsmuse's Avatar
    Quote Originally Posted by dansjustchillin
    Loose chainring bolt, I would presume.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by ionsmuse
    Gotta love four-bolt cranks!
    mtbtires.com
    i also unicycle
    that'd be my guess.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    Reputation: Andy aka Rut's Avatar
    I would have to agree with Ionsmuse.
    Is that really a Boone? Doesn't look like a Boone to me, but I'm used to looking at the spiderless ones.
    Always preach the Gospel; even if you need to use words.
    Ouch, I am hot!
    Must have been. This was my second ride after moving chainring to inside of cranks and my first ride after adjusting it for chain tension. I don't recall a loose bolt, but one was "less tight" than the other three. I just could not get the damn crap chainring bolt tool to grab after a certain point on the last one. Even if one was loose, or looser, I would never have guessed it could cause all this.
    I AM JUST A JERK
    That's just no fun. I lost a bolt last year riding Gooseberry, and now I can thank my lucky stars my Surly didn't get turned into a middle school art project.
    I'm with the Shigganator on this one, five bolts rule.
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    Her-cu-les! Her-cu-les! Her-cu-les!
    That one c-ring bolt that you couldn't get tight no matter what didn't happen to be for a 2-ring setup, did it (i.e., too long)?
    Interlectchewal
    Reputation: tvrbob86's Avatar
    Aug 2005
    Quote Originally Posted by Andy aka Rut
    Yes, that's what the "spiderful" ones look like.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    No Doubt!
    I turned a Surly ring into an oval when I lossed a chainring bolt on my XT cranks.
    The kick in the pants is I'm obsessive about using a torque wrench. Now I've got to check the torque on the XT's every ride for peace of mind.
    My Raceface Turbine LP's (5 bolt) have been set it and forget it for the last 6 years.
    Samsonite Tester
    Reputation: Evel Knievel's Avatar
    The CR bolt may well be the culprit.
    Q: Out of the sadddle when it folded?
    Q: Any latteral flex between rear axle and BB?
    Yeah I gotta question. You got any excuses tonight Roy ? -Antonio Tarver
    There is room for it all, just ride what you like to on what you like to...that's freeriding. -rbn14
    ali'i hua
    Reputation: SlowSSer's Avatar
    wel, I've personally folded a XTR splined ring (jericho- not boone- which i had installed improperly) so i can see this happening.
    note to self- check bolts and throw a replacement into the camelback.
    broken a frame yet?
    Bite Me.
    Reputation: cutthroat's Avatar
    You're obviously pedaling too much. Work on your skills.
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    Dec 1998
    Quote Originally Posted by SlowSSer
    broken a frame yet?
    Which was a three-arm ring. Even less support than a four-arm spider though more than when the 4-arm loses a bolt.
    mtbtires.com
    BMX cranks, 1pc chainwheel. You can do it!!!!
    HB - The God Damn Flying Dutchman
    Chicago Freeride
    Elgin, IL
    Ouch, I am hot!
    Quote Originally Posted by Nat
    Nope, it was the right size and same as the others, as far as I know.
    I AM JUST A JERK
    Reputation: PeanutButterBreath's Avatar
    Curious
    I can see how a chainring would fold if a chainring bolt was loose, but what would cause the crank arm tab to snap off too?
    Bananas...mmm
    Reputation: BizProf's Avatar
    For me, Blue Loctite is a must for chainring bolts. Without some type of threadlocking compound, the rotational force of pedaling tends to loosen even the snuggest of bolts.
    Work to live, don't live to work...
    Reputation: Williwoods's Avatar
    Stop hopping logs. Looks like the damage is from the lack of a bashring. If all I had was the pics this would be what I would assume.
    Nat
    Nat is offline
    Quote Originally Posted by Williwoods
    Yes, those Phoenix trees are nasty!
    Quote Originally Posted by PeanutButterBreath
    The ring being mounted on the inside.
