Would this work? Using a rear derailleur as a tensioner for a single speed full sus- Mtbr.com
Results 1 to 8 of 8
    Reputation: omnom's Avatar
    Mar 2016
    Hi all,
    I am currently building up a Snabb T. However, due to having limited amount of money and being too excited to get the bike. I am currently still waiting on the final parts to arrive which are the wheels and brakes. I decided to go with a single speed option first before buying a proper groupset instead of cheaping out on it.
    For running single speed, I bought the cheapest derailleur I could find which was the Sram x3, as for the rear cog, I bought the Gusset 1-ER Single Speed Conversion Kit.
    I was wondering if this would work on the trails or do you think that it would not be viable and the chain will fall off.
    Thank you.
    Armature speller
    Sep 2004
    I'd go for a short cage derailleur with a clutch to help with chain retention.
    Eg. Shimano Zee.
    i would think a singlespeed tensioner would have been cheaper then a rear derailleur
    Jan 2009
    indeed, a tensioner like Blackspire or DMR will likely be cheaper than a crappy derailleur, and it will work better.
    Armature speller
    Sep 2004
    A sprung single speed tensioner with a clutch would be sweet.
    Mar 2016
    Quote Originally Posted by NordieBoy View Post
    Eg. Shimano Zee.
    Thanks, I'll look into that!
    Quote Originally Posted by mack_turtle View Post
    I was about to order the DMR chain tensioner but saw that there isnt a spring so I thought it wouldnt work with a full sus. Are you talking about this (DMR Simple Tension Seeker & Single Speed Kit | Chain Reaction Cycles) or (http://www.blackspire.com/qs/product...7/263221/0/0)?
    Keep it tight, or your chain could jump.
    Attached Thumbnails Attached Thumbnails Would this work? Using a rear derailleur as a tensioner for a single speed full sus-img_5348.jpg
    Would this work? Using a rear derailleur as a tensioner for a single speed full sus-img_5367.jpg
    Armature speller
    Sep 2004
    Quote Originally Posted by onecogshortofacluster View Post
    Not quite that tight though.
    Not if you still want your suspension to work.
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. Replies: 0
    Last Post: 04-07-2015, 01:59 PM
  3. Replies: 5
    Last Post: 08-29-2014, 05:12 PM
  4. Replies: 16
    Last Post: 08-22-2014, 10:06 AM
  5. Will my 9 speed XO rear derailleur work with 10 speed?
    By TTTURNER in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-21-2013, 05:39 PM
