Working out gear ratios.- Mtbr.com
Results 1 to 5 of 5
    Jun 2018
    Hey guys So I have a 26" dirt jumper which is basically a bmx setup.and I can't figure out the gearing and don't want to waste money on trying multiple setups. So on my bmx I have 28t sprocket and a 9t driver and on the dirt jumper it's a 27t Sprocket with 9t driver. It was 27-12 but it was too easy and now it's too hard Just wondering if anybody knew a formula to calculate 26" to 20"?
    Reputation: Sage of the Sage's Avatar
    You need a gear-inch calculator...
    BikeCalc.com - Bicycle Gear Inches Chart
    Salsa Timberjack SS
    -Gears give me headaches
    Jun 2018
    Oh thank you. This is what I couldn't find. According to this calculator I'll. Need a 21t sprocket on the front. That's pretty small. And will be difficult to find aha.
    You may need to go with a larger cog, so you can run a larger chainring upfront. Easier on the drivetrain bits as well...
    Salsa Timberjack SS
    Jun 2018
    I think if I went a 11t driver on the rear it should be pretty close.
  1. 2x10 sprocket ratios working out great!
    By bakerjw in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2016, 02:28 PM
  2. OK, I searched. Gear ratios for serious climbing?
    By rideit in forum Singlespeed
    Last Post: 08-03-2011, 06:34 AM
  3. Gear ratios and hub engagement
    By rob_co2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-09-2011, 02:51 PM
  4. best gear ratios ever - ActionTec
    By CaveGiant in forum 29er Bikes
    Last Post: 02-07-2011, 11:22 PM
  5. Gear Ratios Question
    By wieczorek24 in forum Beginner's Corner
    Last Post: 01-30-2011, 08:08 PM
