Will a high quality chainring eliminate radial runout?- Mtbr.com
Results 1 to 6 of 6
    Jun 2012
    My chain is tighter in one pedal position than in others. Is that typical of low quality chainrings or of all chainrings?
    Suggestions?
    Jan 2011
    Yes, quality counts.
    Chainrings are generally built and/or finished on CNC machines. Low quality and/or poorly maintained machines move differently in the X vs. the Y position such that parts that need to be round will become slightly oval. Chainrings built on better machines and/or built with a rotary table will generally be more accurate.
    Some slight tight/loose movement is also not a problem and if you use a larger ring/cog your drivetrain will handle the tight/loose just fine. Even with the best rings a very slight tight/loose cycle will occur but it's no big deal and most people don't worry once it is "good enough".
    Sometimes you can correct some of the eccentricity by loosening the chainring bolts and re-tightening them. I think there is a Sheldon Brown page about it.
    Reputation: itsdoable's Avatar
    Sometimes it's the tolerance on the spider.
    There is also some tolerance on the bolt holes, and you can minimize runout by repositioning the chainring (as mentioned in SB's article).
    Reputation: jetboy23's Avatar
    There is also play with freehubs. I can turn my bike over, free spin the rear tire, and i will watch the chain rise and fall a bit. No rotation of the chainring, cog, or chain. Just tightening and loosening from the freehub on the axle.
    Reputation: AndrewTO's Avatar
    Mar 2005
    ^^^ALL of the above.
    The hard part is knowing that just because you spend more money on a product does not mean you actually get a better quality product.
    I ..... need ..... DIRT!!!!!
    ... and cookies.
