White Industries Freewheel tear down - Ernesto?- Mtbr.com
Results 1 to 5 of 5
    I am the owl
    Reputation: riderx's Avatar
    Ernesto - didn't you post a step-by-step on the maintenance of a WI freewheel? I think it's time to crack it open for a peak. I looked on the WI site but couldn't find it. Can you link me up?
    SingleSpeedOutlaw .com
    Riding Bikes and Drinking Beer.
    Reputation: shiggy's Avatar
    Dec 1998
    It is not very complicated.
    Use a Park red pin spanner to remove the lock ring (lefthand threads).
    Gently lift it apart.
    Note the placement of the o-ring and seals.
    Now you can repack the cartridge bearing if needed.
    Clean out any crud in the ratchet/pawls (should be very little).
    Inspect the pawls and springs.
    Use oil (never grease) on the pawls and ratchet.
    Reassemble.
    Easier than repacking a cup and cone hub!
    mtbtires.com
    I am the owl
    Thanks.
    Should you leave the freewheel on the hub to make removing the lockring easier?
    'r you some kinda ssissy?
    Reputation: ssissy's Avatar
    yep,
    to get it loose. then remove the freewheel from the hub and finish removing the ring thing. you can take the fw off all the way before messing with the red/green ring but its easier to loosen when its still on the hub.
    JJT
    JJT is offline
    Reputation: JJT's Avatar
    Check this, it is dutch but the pics speak for themselves:
    Eno Freewheel service
    JJ
    Singlespeed Central - European SS and 29" webshop
