White Ind. Trials ENO Freewheel...- Mtbr.com
Results 1 to 13 of 13
    HTFU and Ride
    Reputation: coachjon's Avatar
    is pretty much the greatest thing ever made.
    that is all
    Winter is coming.
    My spoon is too big!
    Reputation: medieval's Avatar
    Oct 2007
    Wish it came in a 20T.
    "If more of us valued food and cheer and song above hoarded gold, it would be a merrier world."
    J. R. R. Tolkien
    Quote Originally Posted by medieval
    +1 to that
    Reputation: scooter916's Avatar
    its expensive but buy a 20t drive ring with it and swap it out
    you can also swap your front ring out so a 18t will work in the back
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    Turn off the TV
    Reputation: SMT42's Avatar
    Nov 2006
    You can make your own if you have a regular 20 tooth. There is a thread around here that has all the info
    Who could make me a set of Flows with those hubs? I have been reading about them a lot lately and I think I want them for my next set.
    Quote Originally Posted by jkendall
    Your LBS can set you up with the wheels.
    (he thinks he can)
    i just built mine with stan's alpine to a eric's eno hub via dt. rev. spokes and an 18t trials freewheel.. it's the shyt
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
    ..and they place nice together!
    HTFU and Ride
    running mine on a DMR revolver SS hub laced to Halo FreedomDisc 29...just a little burly
    Winter is coming.
    Reputation: henrymiller's Avatar
    I want one, but I see no reason to replace my "normal" White Ind. freewheel.
    Roscoe's Chicken 'n Waffles
    Is the increase in engagement points (10 degrees down to 5 degrees) really that noticeable?
    So, if I have a standard White freewheel, and I want faster engagement without the weight of the full trials freewheel, I can just swap out the hub of the freewheel?
    Chronic 1st-timer
    Dec 2005
    MikeC
    Trailwrecker at large
    one chain, two sprockets
    Quote Originally Posted by coachjon
    I run mine on a DMR Revolver SS too - the 14mm axle version, laced to Sun Doublewides - extra helping of burly...
    Tom P,
