White Ind Lockring w/o the tool....how?- Mtbr.com
Results 1 to 9 of 9
    N+1
    Reputation: MichiganClydesdale's Avatar
    best methods for tightening or removing the White Ind Lockring? thanks for the help. Tool ordered, but need to get the lockring tightened down.
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    Quote Originally Posted by MichiganClydesdale
    Screwdriver, hammer, bam-bam-bam!
    used to be uno-speedo....
    Reputation: dirtdrop's Avatar
    Take it to a shop with a bottom bracket removal tool?
    i ride bikez!!11!
    Screwdriver and hammer work much better on that White Ind lockring than BB tools. The diameter is small and harder to get much torque on. Just ask all of my knuckles.
    Try to find a punch or something with more surface area. I have never owned a pair of their cranks, but I find that when tightening lockrings (like on my fixed gears) it is easier to get them torqued down tight if you can pin the tool against something and rotate the wheel. The frame works perfectly on one of my bikes. For the cranks, if you can get the tool on and rotate it around until it hits the chainstay, then apply pressure to the cranks it will keep the tool secure and allow you to tighten it further or easier. And since they are cranks you can use your leg
    N+1
    Quote Originally Posted by Schmucker
    pin the tool against something and rotate the crank arm
    good advice, and it worked pretty well. thx all
    Quote Originally Posted by xmynameisdan
    btw, yes, I see what you mean...one bashed knuckle with bandaid.
    Reputation: mtbyker's Avatar
    Mar 2006
    Pipe wrench with a rag around the ring.
    Ozark Native
    Reputation: lil hillbilly's Avatar
    May 2005
    give this a shot
    if your talkin about the lock ring that holds the chainring to the cranks use one of these.
    http://queencitycycles.com home of the shiftless bastards
    Nat
    Nat is offline
    Quote Originally Posted by lil hillbilly
    He said he ordered one and was looking for some other method while waiting for it to arrive.
