White Ind. ENO crankset question- Mtbr.com
Results 1 to 15 of 15
    Reputation: shalesjr's Avatar
    I just purchased a White Industries Eno crankset. I need to get a square tapered bottom bracket. Any suggestions???
    igoslo
    Reputation: SoloRider's Avatar
    Quote Originally Posted by shalesjr
    One more question. Will any square tapered bb work? It will be going on a Vassago Jabberwocky. 68mm shell.
    *Hotter than Hell*
    Aug 2005
    PROFESSIONAL THREAD KILLER!
    Quote Originally Posted by FoShizzle
    Maybe I will just start hanging out in the "Recycle Bin" forum.
    Reputation: ernesto_from_Wisconsin's Avatar
    would you recommend the 113mm or the 121mm for a single speed setup on a Jabberwocky?
    i have to ask
    I have to ask because I am not familiar with the Vassago frames.
    100% recycled
    Reputation: afie's Avatar
    Needs to be JIS square taper. WI recommends a 113mm width.
    Phil wood ti is 156g and $150, the steel version is 226g and $106. Compare to a shimano UN54 for $20.
    I definately like the $20 option. Has anyone used the UN54? If so, what did you think?
    Reputation: AteMrYeats's Avatar
    Quote Originally Posted by afie
    113mm with a White hub. Check the chainline first, then buy the bb. My guess is the original poster will need the 121mm.
    Those mountain bikes that yet / Fresh mountain bikes beget
    you may be able to find a un73 on ebay, discontinued but a great bb for the price
    enjoying the kool-aid
    Reputation: Chewieez's Avatar
    If you can find a UN73 that's what I've been using for the past two years, and I bought the bike used. it's still spinning great. I just took it out and checked it out and all looks good.
    Phil is good and blingy, but lots of $$.
    Reputation: SSSasky's Avatar
    I run the UN54 on my fixed gear and SS. Works fine. Nice and cheap. I usually get about 1 year on mine.
    Been using the UN54 for about a year, no troubles whatsoever (though haven't rode in the wet). Installed first with grease, had some creaking and added teflon tape - problem solved.
    The White Ind. BB looks nice though.
    Welcome to the Gem...
    Reputation: Mallanaga's Avatar
    i run the ENO cranks on my jabber with the UN54 BB. it can be a bit creaky at times, but it spins good.
    for size, 68 x 113 is perfect with my ENO FW. the chain line is perfect...
    Ibis Tranny 29
