Where to find a 52t 130 BCD dedicated SS ring- Mtbr.com
Results 1 to 5 of 5
    Reputation: anvil_den's Avatar
    Nov 2007
    I was searching for 2 nites and could not find something suitable.
    Just set up the bike http://forums.mtbr.com/showthread.php?t=597798
    and while the 48 ring that came with the crank was a snug fit with a 1/8" chain, it just wasn't enuf so I swapped it to an old Shim 600 ring, 52t. Thing is I don't like the thinness of it that gives the side to sdie play with the chain.
    Seems like all the thicker big rings are mostly track stuff (144 BCD). Is there any like that but with a 130 BCD?
    Reputation: asphaltdude's Avatar
    Specialites TA Alize Piste, sweet 1/8" 130mm BCD ring.
    Blackspire Mono Veloce are available up to 50t.
    Ride more!
    one chain loop
    Reputation: fishcreek's Avatar
    my bad, deleted post.
    everything sucks but my vacuum cleaner.
    Reputation: bd.sahib's Avatar
    Aug 2005
    I had a 52 from Salsa. Ran it w/ a pc-1 and 1/8" surly fixed gear cog w/o issue.
    Salsa Chairing Link
    Nov 2007
    Thanks to all!
    The Specialites TA Alize Piste and Salsa looks good.
    I have the Veloce, a 46t for light touring/commuting on another bike, same issue, not quite thick enuf with 1/8" chain.
