What's going on with my wheel?- Mtbr.com
Results 1 to 7 of 7
    Bought a new Redline Flight this year and it came with the Alex Dh wheels. I am 215 lbs and ride pretty hard cross country. The wheels held up all summer. I never touched them and they were really solid. A few weeks ago I noticed two spokes on the rear were really loose after a ride so I took the wheel in to my LBS. They said the hub was loose and that is why is the spokes came loose. They fixed the wheel and I was good to go. Today, after only three rides, ever fourth spoke is very loose. Is this happening because the wheel is cheap? Should I look into a better wheelset that will handle hard riding by a fatass? Any thoughts?
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    I say take it back to your LBS. They said they fixed it, but in fact made it worse.
    It's interesting that every fourth spoke is loose. Are the loose ones the leading spokes on the non drive side?
    Reputation: Brewtality's Avatar
    Sounds like common issues with a cheapo machine built wheelset. At the very least, the whole wheel needs to be fully released and then retensioned, using linseed oil on the spoke threads.
    You might consider using all new spoke to have the wheel completely rebuilt.
    Its all Shits and Giggles until somebody Giggles and Shits
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    And while you are at it replace the rims.
    Raised in a Chicken-Coop by Chickens
    Bro Mountainbiker
    May 2010
    and the hubs.
    Reputation: Sage of the Sage's Avatar
    +1... you might be better off to upgrade instead of rebuilding
    Salsa Timberjack SS
    -Gears give me headaches
    Bro Mountainbiker
    May 2010
    I was just making a joke but it an option. If you are going to go to the work to untention and then pay a wheel builder to retention the spokes with spoke prep, you may as well get something cool out of it. Like a fly wheelset.
    But if money were an issue, I would try bringing the spokes up to even tension as is, and dropping 2 drops of Loctite #609 into the nipple. 609 only! It will keep the nipples from rattling loose and it will also prevent corrosion.
    Linseed oil works too if you live in a drier climate and give it time to dry.
    The last wheels I built came apart because i diddnt give the Linseed oil time to dry + I live in a humid place...
  1. Front Wheel Pings After Putting Wheel on Backwards
    By jscott36 in forum Wheels and Tires
    Last Post: 12-03-2010, 03:14 PM
  2. Replies: 13
    Last Post: 08-04-2009, 02:54 PM
  3. Replies: 3
    Last Post: 07-29-2008, 03:59 PM
  4. Replies: 6
    Last Post: 05-14-2007, 06:40 AM
  5. Any way to modify a rear disk wheel to fit as a front wheel ?
    By th3crack3r in forum General Discussion
    Last Post: 04-05-2007, 05:43 PM
