Results 1 to 5 of 5
    What's the biggest tire to fit a surly 1x1?
    hi guys,
    the new pugsley has me a thinkin'. what it the biggest tire that will fit a 1x1 while running canti brakes?
    thanks so much for the help.
    rick
    drinker
    i have run nokan gazzi 2.6's on my 1x1. mounted to mavic 519 rims, and using magura rimmers.......
    3.0 gazz
    I have 3.0 gazz on Marge(65mm) in my 1x1, but the rim won't clear the brake studs, requiring a disc brake. But any other narrower rim/3.0 gazz will work fine.
    AlaskaPat
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by patirwin
    AlaskaPat
    ...And you would probably need to use cantilever brakes rather than V-brakes. The V-brake cable may not clear the top of the tire.
    mtbtires.com
    Ride Bikes, Drink Beer
    Reputation: Farmboy's Avatar
    Sep 2004
    Nevegal 2.5s
    I ran Kenda Nevegal 2.5s last fall and winter. I had plenty of clearance on the sides but the slightest buildup on the tire would rub my Vbrake noodle a little bit, but not enough to cause damage.
  1. Want to know how big of a tire can fit the MX comp?
    By BudhaGoodha in forum Shocks and Suspension
    Last Post: 06-04-2005, 05:08 PM
  2. What's the biggest tire you've fit on your Bianchi S.S.?
    By grumpstumper in forum Singlespeed
    Last Post: 05-02-2005, 06:03 PM
  3. Biggest tire on Boxxer - 2.8 Michy fit?
    By Dontgothere in forum Downhill - Freeride
    Last Post: 07-30-2004, 12:26 PM
  4. New Surly 1x1 porn
    By Earthpig in forum Singlespeed
    Last Post: 05-20-2004, 09:41 PM
  5. Replies: 2
    Last Post: 04-30-2004, 01:26 PM
