What speed chain for wolftooth/ white ind.?- Mtbr.com
Results 1 to 7 of 7
    Dec 2015
    I have a white industries freewheel and am changing my chainring to a wolftooth eliptical. White industries recommends an 8 speed chain with the freewheel. Wolftooth recommends a 10 speed chain with the chainring. What size (speed) chain would you run? I'm inclined to run an 8 speed or a 9 speed and just accept that it's a bit loose (wide) on the chainring. Has anyone run a 10 speed chain on a white industries freewheel? Thanks.
    Jan 2009
    anything 8-10 speed should work. a 1/8" chain would be silly. most people seem to like 8 speed chains on SS drivetrains because they are cheap and you don't get much benefit from a higher "speed" chain, if any at all.
    Armature speller
    Sep 2004
    I'd run a 9-10 speed chain if the rear can handle it.
    Reputation: AlexCuse's Avatar
    I would just use an 8 speed chain (most 9 speed and I think all 10 speed chains are 11/128). Are you worried the ring will wear prematurely or something?
    Yeah I only carry cans cause I'm a weight weenie.
    Dec 2015
    Quote Originally Posted by AlexCuse View Post
    I don't care about premature wear. I just want to run a chain that's not too tight on the white ind freewheel and not too loose on the wolftooth chainring. Has someone here used an 8spd chain on a wolftooth chainring? Thanks.
    Reputation: dbhammercycle's Avatar
    I'm going to be running an 8spd chain, Sram 870, with my WI Eno and Absolute Black nw oval ring, which I think is 10spd. I'd rather fit to the recommendation of the WI Eno for a better fit than the chain ring. My guess is that since there are fewer teeth on the WI Eno perhaps the chain would be more likely to fall off the freewheel if there was a fit issue. Sure, the chain may be a little wider than needed for the ring, but with more teeth and proper chain tension there shouldn't be much of a worry. Honestly, I think with proper chain tension and good chainline you shouldn't have to worry regardless of the chain you choose.
    I have no idea if that is correct or makes any sense, but that's what I'm doin'.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Did I catch a niner+?
    I've been using 8 speed chains for as long as I can remember, they are so much cheaper than the higher gear models. I think the last one was $6. Also I use a Rennen Chainring which is N/W before N/W was cool and you're not going to have any issues, I use a king SS cog out back and again no issues.
  1. 11 Speed cassette, chain, rear mech and shifters with 10 speed cranks/rings.
    By devans in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2015, 01:47 PM
  2. 10 speed chainring with a 9 speed chain and 9 speed cassete
    By adrianfleming in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-09-2014, 11:17 AM
  3. Wolftooth chain ring with XX1 chain
    By Unforgiving in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-01-2014, 11:11 AM
  4. Can I use Sram 9 speed quick link gold with shimano 9 speed chain
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2012, 06:06 AM
  5. Can I use part of Sram 9 speed chain with Shimano 9 speed chain
    Last Post: 01-08-2012, 07:30 AM
