What puts a rigid, ss out of commission?- Mtbr.com
Results 1 to 49 of 49
    Answer: headset.
    Well, for me, at least. The last few rides, I havent been able to keep my headset tight. It is really loose..DANGEROUSLY loose.
    It is the stock headset on the 2009 Xcal (Cane Creek Aheadset, zerostack). I have had the bike rigid since the spring.
    Question: is it worth taking to a shop to have it looked at or should I just order a new headset and upgrade to something that might take a beating? I havent known of anyone saying rigid destroyed their headset...
    I am home sick today and Jenson is about to get a lot of my money...
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    to answer your question - i broke a cone on a climb...that wound down slowly and crushed my bearings in the rear wheel...effectively seizing it
    had to carry bike for a few miles back to car..
    as far as a headset - have you been riding with a loose one for a while...is your HT ovalized (hope not)?
    i'd have a shop look at it - if it needs replacing buy a headset there
    my .02
    Click Here for Forum Rules
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Are you over tightening it, pulling the star-nut "out" and actually loosening it when you are trying to tighten it?:
    I think CHUM is right though, unless you have calipers to measure o.d., and i.d., and feel comfortable pulling the old one to measure and pressing in a new one, you should go to the shop.
    Dec 2010
    Hey I have a similar issue with the headset on my rigid ss. But the solution for me and my bike is facing my headtube. I'm getting a new headset anyway. But another thing that gets a rigid ss out of comission is a broken freehub body I'm putting my new freehub in this week
    I got nothin'
    Reputation: hydrogeek's Avatar
    Feb 2006
    I have been down this road before. My issue was that the stem was moving on the steer tube. The solution was to clean the steer tube and the inside of the stem really well with alcohol or an equivalent solvent. Then re install and torque the bolts equally to spec.
    I had one rigid setup that I could not make work no matter how clean the parts were. The solution was to put a little loctite between the stem and the steer tube. Worked like a champ.
    I ride at ludicrous speed
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    My rigid has destroyed my pos sunline headset. It takes constant maintenence or it indexes, grinds, and clicks + pops. Time for a Chris King or a Cane Creek 110.
    Raised in a Chicken-Coop by Chickens
    Reputation: monzie's Avatar
    I have a CK; I have no problems. Hehe. Loose headsets suck though. I just had my Bianchi Pista looked at for this reason. The fork was stripped and the headset was thrashed. Ended up trading the cost of shipping the wheelset to Raleigh for the frame.
    Quote Originally Posted by Tone's View Post
    Id scrap the passion forum all together, its a breeding ground for unicorn milkers, rainbow chasers and candy cotton farters.
    4 days of straight rain has put my ss out of commission.
    Friends don't let friends ride geared bikes
    one chain loop
    Reputation: fishcreek's Avatar
    slow shipping of parts made one of my ss out of commission.
    everything sucks but my vacuum cleaner.
    nothing to see here
    Reputation: Stevob's Avatar
    OP definitely needs to get a shop to look at it. Don't waste money on a new headset unless you know the head tube is reemed and faced.
    I see hills.
    I want to climb them.
    Stokeless Asshat
    Reputation: jeff's Avatar
    Sounds like the star nut to me.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Jan 2009
    I ride a properly faced Monocog with a Surly fork and a Chris Kind headset. it's flawless. adjusting the headset should not be difficult, but if it keeps coming loose, get it checked out.
    are you sure you have enough spacers under your stem?
    Check also that there's enough clearance under the top cap (where the bolt goes through) to the top of the fork.
    If there's not enough clearance, the cap bottoms on the top of the fork, and no amount of tightening will help. As others have said, what usually happens is the star nut begins to back out.
    I'm speaking from experience here....
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    What everyone else said + take your stem bolts out and clean/grease the threads & base of the heads before re-installing. It will make your torque wrench reading more accurate.
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    Low Rep Count
    Reputation: 1SPD's Avatar
    My current King hs has been strange compared to all others I have had in the past (about 5 or 6 on different bikes). This one has installed the same and worked great only to start making some creaking noises while riding. I then found that it somehow got tighter and even the steering was slower. I then loosened it up a tad, got the steering back to the way it should be w/out any looseness/play and all was good. Then it seemed like it got looser. So I tightened it slightly only to have it seem to tighten up on me again????? Not sure wth is going on with this damn thing. The one I took off did not do that at all!
    Fat & Single
    Reputation: ozzybmx's Avatar
    SS well out of service, owner has caught the deadly Man-Cold... bike has not turned a wheel in 10 days.
    Santa Cruz Hightower LT Evil Following Trek 9.9 Superfly SL IndyFab Deluxe 29 Pivot Vault CX Cervelo R3 Disc
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Somehow, I managed to strip the BB shell threads on a SS bike...
    (external BB)
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Quote Originally Posted by Andrea138 View Post
    subtract 10% to torque specs when ya do that...
    edit: GACK! i meant subtract not add...my bad
    Really? Never done that before & haven't had problems. Not saying you're wrong. I'm just a n00b.
    CB2
    CB2 is offline
    Jam Econo
    Not really. They come up with torque specs based on size, material and thread pitch with clean, lubed threads. There is no way for them to account for how grungy or not you threads are to come up with the spec otherwise.
    Dear Perttime: You sir/ madame are simply that cock- diesel that you can strip external BB's. one would be tempted to say gorilla; Silverback even.
    I was totally WRONG - subtract 10% (not add)...ugh
    Quote Originally Posted by CB2 View Post
    i got the tip from this dude:
    http://forums.mtbr.com/6278544-post20.html
    For me, the first thing to go on any SS is the bottom bracket. Either I'm particularly hard on them to begin with, riding SS adds more stress than a geared setup (just speculation--I have no proof of this), or I've just had a bit of bad luck.
    Mar 2006
    The rider as he has ridden his rigid ss far far too much and is so tired that he is going to bed.
    Gigantic Hawk
    Reputation: dubthang's Avatar
    Quote Originally Posted by Sheepo5669 View Post
    I'm using a Sunline V2, and haven't had any issues yet. How long did it take for yours to show up?
    Ride da mOOn Moderator
    Reputation: NEPMTBA's Avatar
    Wink
    "BEER"...
    ... and a lot of it will put a rigid ss out of commission!
    Fat & Single
    Quote Originally Posted by NEPMTBA View Post
    "BEER"...
    +REP.... i dont have a problem ok .
    Reputation: MOJO K's Avatar
    The rigid SS, like any really cool toy, mostly gets put out of commision by the arrival of the next more really even cooler toy.
    MERCY! MERCY! MERCY!
    I was descending Dead Woman Hollow at Michaux, not much spinning of the cranks as Dead Woman is a fast downhill stretch of dirt forest service road so a single speed ridged is spun out most of the way. I noticed at one point that things were very, very, quite. I spin an I9 rear hub so things are never very, very, quite when freewheeling. Now did it dawn on me to wonder why things were so quite. No! Not until I reached a section that required me to pedal did I also realize that for pedaling to actually work it requires one to have a chain.
    I walked all the way back to the top of Dead Woman then back to my bike and never found that chain.
    Quote Originally Posted by MOJO K View Post
    Except there's nothing cooler than a rigid SS.
    DOH!
    Reputation: IBBW's Avatar
    Mar 2006
    Riding a habitually loosening headset and not fixing it or finding out why it is coming loose on your rigid sled can lead to a cracked head tube. It KIA'd my bianchi that way.
    what don't kill ya, make ya more strong.
    Fat & Single
    Quote Originally Posted by monzie View Post
    They are the Buzz Lightyear of the bike world
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    I say woody not buzz.
    burnedthetoast
    This morning, a broken tensioner put my rigid SS into a bad place! Monocog and me were late for work...
    "BEER"...
    Nah, just makes me piss on your dog and screw your wife. Unless I'm really bad, then I piss on your wife and screw your dog......There's usually police involved, too.
    Low Rep Count
    I should add that normally the bike is working pretty well. What puts my SS out of commission is normally my wife and kids! I swear they can ruin a wet dream!
    Problem fixed! As it turns out, I had the bearing cups switched. Once I flipped them around, the headset snugged up. I rode the hell out of it yesterday and no loose headset.
    Low Rep Count
    Fortunately, my King has the word "King" printed on it to help ensure that doesn't happen.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    cracks
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Low Rep Count
    WTF! Sorry man! That sucks. Can I have your headset?
    Quote Originally Posted by 1SPD View Post
    Warranty replacement, so all's good.
    The new frame has a beefy gusset that's for "suspension fork knob clearance." Sure.
    Headset's being put to good use.
    Low Rep Count
    Glad to hear you got it taken care of!!! No worries, I already have a red King hs anyway!
    Bro Mountainbiker
    May 2010
    Quote Originally Posted by dubthang View Post
    I have been riding hard on it for about 8 months but it came in the frame i bought second hand. So I dont know how hard or long it had been ridden before i owned it.
    Sorry about the late reply.
    Sheepo
    Reputation: heyheyitselliej's Avatar
    Quote Originally Posted by meltingfeather View Post
    cracks
    Is that a Soma Juice frame?
    Jun 2012
    it isnt the headset it is the stem.. go to a dh or dirt jump stem
    Gigantic Hawk
    Sheepo
    I just saw that you had replied.. so I guess this will be a late reply too.
    I've had my V2 on my Canfield for over a season now, and it's running strong.
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Quote Originally Posted by b0mb3r View Post
    Wait, I thought the whole point of SS was that it can't be limited by foul weather... Oh, and my headset decided it wanted to start creaking suddenly yesterday.
    Quote Originally Posted by rydbyk View Post
    true but you don't want to be the a-hole who goes and destroys the trails.
    Reputation: rob1035's Avatar
    my legs and lungs keep mine out of commission...
  1. Anyone else out of commission?
    By mattbryant2 in forum Riding Passion
    Last Post: 11-26-2009, 09:40 PM
  2. New BB puts chainline out
    By chris3005 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-04-2009, 05:08 AM
  3. Out of Commission
    By Blue Shorts in forum California - Norcal
    Last Post: 07-05-2007, 05:02 PM
