What front ring(sixe) paired with a 16t back ring will..- Mtbr.com
Results 1 to 11 of 11
    What front ring(size) paired with a 16t back ring will..
    give me a similiar if not slightly smaller ratio compared to my 50t front and 17t rear???
    also have very short movement on the rear dropouts (12mm )?????
    many thanks
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    Idea!
    47x16 will be almost exactly the same gear, and your wheel should be in almost exactly the same position in your drop outs. You will need to shorten your chain.
    Quote Originally Posted by 31trum
    many thanks
    Todd............. If you can't be kind, at least have the decency to be vague
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    many thanks
    This guy will also help you figure it out:
    http://sheldonbrown.com/gears/
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    many thanks
    C'mon, 7th grade math:
    50/17=X/16
    Solve for X.
    Wink
    Quote Originally Posted by Nat
    50/17=X/16
    Solve for X.
    Who makes a 47.0588235294 tooth ring again?
    Nat
    Nat is offline
    Quote Originally Posted by Drevil
    C'mon...
    Reputation: kenpuke's Avatar
    Oh snap! You went 'dere!
    I hope that 47 tooth ring is for road riding b/c that sucka must have legs like tree trunks if he can ride that gearing on trail...
    Smile Thanks to all especially..........
    32/17 and Drevil for the most informative/sensible answers.
    Nat, for reminding me how long ago i was in 7th grade,....(30 years)
    and to Kenpuke .....road 8^)
    I'm sticky
    Now we're going back to 3rd grade... rounding numbers!
    But seriously, a 42 year old should be able to do simple math.
    Quote Originally Posted by pcrap
    Phew! Tough crowd...
    I'm sticky
    Spaz.
