What do I need to change my gearing?- Mtbr.com
Results 1 to 10 of 10
    I am looking at putting different gearing on my Surly 1x1, I am currently running a 32/16 however now that the snow is down I need to go to a 32/20 or so. I am running a Surly single speed rear hub which has a Shimano SF-mx30 on it.
    Would I need to get the 3/32nd track cog or the 1/8 Track cog? Also would I need to buy another lock ring or will the Shimano one work with a Surly cog?
    Also which tool would you use to remove the lock ring? I found a Freewheel remover for BMX wheels so I am assuming that it what I will require.
    Reputation: asphaltdude's Avatar
    Ehm, I think you'll need a freewheel, not a track cog.
    Ride more!
    Ok, now that seems to make more sence. Is there a company who makes better freewheels with 20 tooth cogs? I see Shimmano's only go to 18 tooth.
    Nov 2008
    I think White Industries has a 20
    Reputation: rzims's Avatar
    I went through a few shimano and ACS freewheels last year. They would be fine for a while then would start the "clicking" which drove me nuts.
    I bought a white industries freewheel and never had another issue. It's quite a bit more expensive, but worth it for me.
    1 ☼ ♥
    Reputation: mrkaztro's Avatar
    Nov 2008
    Good job! W I without a doubt
    White Industries is the way to go!! You won't be disappointed!
    Get a White Industries and forget about it.
    Ok sounds like a plan now I just need to sneek buy a 16, 18, 20 tooth ones. If you don't hear a reply with in a week my wife found out.
    Reputation: anatomydan's Avatar
    Nov 2008
    i have an ACS 20t and it "clicks" and "clunks" like crazy (very annoying). i am saving up to get a WI 20t. the cheapest i have found them is on bikeman.com for around $70.
    by the way...can i borrow $70
    Oldie
    Reputation: zuk88's Avatar
    Feb 2005
    I work next door to White Industries...maybe I can sneak in while their bay door is open and grab a box full....I can't afford their stuff either.
    "You don't need a lighter bike, you need bigger muscles"
