What cranks for Phil Wood EBB?- Mtbr.com
Results 1 to 2 of 2
    I'm pretty sure I'm going to order a frame with a Phil Wood EBB as my first singlespeed bike. Will any crankset fit this bb? At present I have XT cranks, which I was planning on using until I got something ss specific. Will these work with my new frame (usually setup with external bb)? What's everyones recommendations for a ss cranket that will fit the EBB. Thanks for your help, I'm going into this pretty blind!
    Reputation: scooter916's Avatar
    any crankset/bb should work, just make sure you use the proper spacers if needed. Most EBB's are 68mm
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
