What chain to use on my new SS- Mtbr.com
Results 1 to 13 of 13
    Reputation: K4m1k4z3's Avatar
    I'm planning to convert my GT Moto to SS using Da-Bomb chain tensioner (not the spring one). And I'd like to know whether I can use BMX chains like KMC Halflink etc. I'm really confused.
    I'd be glad if you could recommend me some good chain.
    Thanks in advance.
    Reputation: FlatFender's Avatar
    I ran a sram PC-1 for a bit, but then it started to get some still links out of the blue, now I run $5 KMCs.
    Reputation: philpot's Avatar
    Who cares! If you're a weight weenie buy a light one. If you're a masher buy a strong one. If you're rich buy a gold plated one. Its not shifting just going around and around!!!
    I use..........
    Pc-48
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    I use any " big brand" 8 speed chain that is decently priced
    Pees in your sink
    Reputation: Rottenmac's Avatar
    Feb 2007
    I just got the Eastern Bondage chain for my Karate Monkey. It looks cool and is indestructible. And, yes, you can run a KMC stainless one for 10 bucks. Lube it and forget it.
    If you have SS'ed it and are using a chain tensioner, then maybe just go for a cheaper one, since they are easier to replace cost-wise.
    I agree about what you're using the Moto for. If you're doing DJ/4X stuff, you will want a BMX-style one to handle the abuse. If you have mad skills, then you can get away with a lighter MTB chain.
    A chain is a chain is a chain.
    What do you mean there's a 7 A.M. as well?
    Combat Wombat
    Reputation: BrianU's Avatar
    Something to keep in mind.
    Quote Originally Posted by K4m1k4z3
    Thanks in advance.
    I do not know about these tensioners, but you might want to find out if a 1/8" chain will work with them. I looked at the 3 different Da-Bomb tensioners and while I could not find anything about this, they are sold as a way to convert your 8/9 speed drivetrain to SS. I run a 3/32" KMC Z610HX chain. http://www.aggrobikes.com/product_in...roducts_id=132
    This is a dedicated SS chain, so it has a regular masterlink . If you do a search on this subject, these chains also seem to have a pretty strong following.
    Brian
    Quote Originally Posted by BrianU
    Brian
    It's THIS tensioner. I thought of KHE Standart chain 1/2" x 1/8".
    time to climb
    Reputation: Paulie's Avatar
    Bondage chain is sick
    Quote Originally Posted by Rottenmac
    Gotta have one. Where did you get it? I tried to find it on the web. Only German and Brit companies; both do not even list U.S. as a shipping destination. Is there a webpage?
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    I use KHE chains. I use the hollow pin "weight weenie" variety 3/32" chain. But any chain that matches your cog and chainring will work.
    I had tried a KMC 8spd "X" chain because I had it lying around, but the way the side plates were cut to make shifting easier also made it easier for the chain to collect dirt.
    just have fun!
    Reputation: desurfer's Avatar
    I use the $8 KMC BMX chain. Cheap and tough.
    Retro Grouch
    Reputation: aka brad's Avatar
    I would go with 3/32 chain..
    Brian
    The product descriptor states, "Roller type chain tensioning device to convert your 8/9 speed bike to single speed. Attaches to vertical or horizontal dropouts." The roller may not be able to handle an 1/8 chain. Check out http://www.pvdwiki.com/index.php?title=Bicycle_Chains for some good chain spew.
    1G1G, Brad
    Just one more rep and I get the toaster!
    mtbnj.com
    Reputation: walter's Avatar
    I use the KMC as well, my bike shop guy told me my legs will snap before the chain does
    You guys live or plan on coming to New Jersey, check out mtbnj.com
