what 31.8 carbon FLAT bars come longer than 600mm??..- Mtbr.com
Results 1 to 13 of 13
    Reputation: ajbuilder's Avatar
    Mar 2006
    Salsa is all I am coming up with...anyone else???
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
    awesome
    Reputation: dblspeed's Avatar
    Salsa pro moto, Titec (forgot the name), both in 660mm
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by ajbuilder
    Syntace Duraflite 31.8 Carbon:
    http://www.syntace.com/index.cfm?pid=3&pk=1496#
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Mar 2006
    I've heard that carbon are laterally stiff when climbing but will eat up some small vibrations.......can anyone confirm this?
    Bored
    Jan 2003
    Cannot confirm for Carbon, but I do know with good butting on an aluminum bar, it makes a big difference. I really noticed that early this year when I put on a Salsa ProMoto bar.
    Reputation: nspace's Avatar
    Just started riding the Pro Moto with 11 degrees sweep on my rigid 29er and it has been great. Comfortable hand position, and it has felt very stiff (keep in mind I am only 138 lbs). Soaking up small bump vibrations has been pretty good, but I also have a carbon fork which helps.
    Mar 2006
    the Syntace looks good, who carries them? I need to find one......
    I have the Salsa ProMoto 11deg aluminum bar on there right now --the 25.4mm version and it is crazy flexy, so I'm upping it to 31.8 but want to try carbon
    Bored
    Jan 2003
    I came across this today. should meet some of your specifications:
    http://cgi.ebay.ca/ORIGIN-8-PRO-PULS...QQcmdZViewItem
    Dr Gadget is IN
    Reputation: wadester's Avatar
    colorful aluminum
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Be careful, this bar has some serious sweep IIRC that may feel weird. Definitely try to find one to feel before you buy it.
    Reputation: Johnny Chicken Bones's Avatar
    Syntace Vector Carbon
    They are 680mm wide, have a 12d sweep and 10mm rise.
    They aren't totall flat but they are close, they even look flat...ish.
    I have a set on the Moots SS. Each time someone tries the bike they first remark about the bars.
    http://www.syntace.com/index.cfm?pid=3&pk=1529
    --------- __o
    ------- _`\<,_
    Running is for prey.
    Syntace has a couple different bar options that are all awesome.
    Any shop that deals direct with Magura can get you the best options (they come over in small batches and are sometimes hard to track down).
