What 29er steel non ebb slider style frames are out there?- Mtbr.com
Results 1 to 8 of 8
    Reputation: heyheyitselliej's Avatar
    I'm currently trying to find a frame for my 29er ss build. My requirements are as follows:
    Steel
    Non EBB
    I want sliding dropouts (paragon sliders, etc.) so I don't have to mess with my rear disc brake so much.
    Clearance for big tires (I might run a Weirwolf LT 2.55)
    So far these fit the bill:
    Voodoo Dambala (tire clearance is supposed to be ok now?)
    Kona Unit
    Redline Monocog Flight
    Any more production frames out there? I'm looking to spend about $750 or less.
    Thanks,
    John.
    Are you sure 2.55's fit on the Flight? I put 2.3's on there and they fit fine, but 2.55's would be really close.
    I chose the Flight for the fit, price and lifetime warranty.
    can you buy the monocog as a frame set?
    Reputation: gjenkins@'s Avatar
    I am confused ... it seems like an EBB, with fixed rear axle position, would make for an easier rear brake set-up.
    Quote Originally Posted by DropOutBro
    Not usually. I did find a bike shop with some Flight frames, though. Might want to check with your local dealer. Otherwise, you can buy the whole bike for ~$700 and sell off what you don't want.
    Oct 2007
    Did you check out this thread? Nice looking frame and sweet drop out, no disk brake mess. can be run SS, SS belt, or 9/10 speed. Looks cool.
    http://forums.mtbr.com/showthread.php?t=604119
    IIRC, the Spot frames are much more than the OP's budget. Awesome frames, though.
    With regard to the Flight's tire capacity, I was thinking that I had stumbled upon something online that mentioned 2.5 for a tire size. It seems pretty easy to find monocog frames used though.
    I've thought long and hard about going with an ebb; it sure would make my search for a frame go easier, but in the end I'd rather keep it simple. My current ss has horizontal dropouts, which can be a pain, so I'm hoping a frame with sliders will be a good compromise.
    Spot would be nice, but its pretty much out of my price range.
