Weak tension on Surly Singleator- Mtbr.com
Results 1 to 13 of 13
    I've had a Singleator for a few years and replaced the spring once or twice. I had a couple chain drops so replaced the spring again, but tension seems pretty weak. I made sure to to loosen the hex bolt, while putting tension on the spring. I may have overtightened the spring initially, but tried it a couple times and something still seems off.
    Any recommendations? I may take the full thing apart, clean it, re-grease it and try it again.
    Reputation: A1an's Avatar
    Did you follow instructions on how to tension the spring?
    http://surlybikes.com/files/NewSingleatorInfo.pdf
    Signature
    Jan 2009
    recommendation: get rid of the Singleator. I had one and it generally sucked. If I did not have a SS-able frame, i would be running a DMR tensioner or, even better, a Blackspire Stinger.
    Quote Originally Posted by A1an View Post
    Yeah, but still no luck. The chain isn't dropping but it's quite loose.
    Quote Originally Posted by mack_turtle View Post
    Thanks for the recommendations. I'll probably give one of those a shot
    Jan 2009
    how worn are the chain, ring, and cog?
    Armature speller
    Sep 2004
    I'm running a Singulator in push up mode and a DMR STS in push down mode.
    Both work nicely.
    The chain is slightly stretched so I'll probably replace it when I get the new tensioner. The chainring and cog seem good. Not sure how much that would affect the tension strength tho?
    Reputation: OwenM's Avatar
    Oct 2012
    Zip tie it, but don't overtighten it. Watch the tensioner move up and down as you turn the cranks-you want to maintain that freedom of movement, or the pulley will be fixed against the chain, putting stress on the pulley and creating both noise and noticeable drag on the chain.
    You're not holding it in place, just limiting its travel, which its spring isn't strong enough to do on its own.
    Not at home, so I can't post a pic, but I use two zip ties. One loops around the arm the pulley is on with just enough clearance for the other zip tie, which goes through it, and over the chainstay. It's less noticeable than looping a tie around the tensioner itself, like I've seen many pictures of. May not make any real difference, but I like that it's pulling straight up on the pulley arm rather than putting pressure on it from the side.
    Feb 2005
    Like this?
    Hope the photo is good enough
    Attached Thumbnails Attached Thumbnails Weak tension on Surly Singleator-036e4435-4f51-4b38-b68d-9e33191a8f83.jpg
    Oct 2012
    Mine is just like that, except I made the bottom loop very small-same thing.
    Yours work ok?
    Feb 2005
    i am running the Singulator for almost 2 years, and every several months need to take it apart and re assemble it, last month it started to mis-behave, had a chain drop every ride... so this morning i zip tied it seems to work well so far (1 ride) will see how it goes
    Stubby-legged
    I have two singulators and a rennon that I would trade or sell for about anything....
    Oct 2013
    I've had 2 Singleators. I think they suck. Had good luck with a Gusset Bachelor.
  1. Where can I get a Surly Singleator replacement spring?
    By bank5 in forum Where are the Best Deals?
    Last Post: 03-25-2016, 05:33 PM
  2. Fixing the Surly Singleator - making it unsprung
    By vuduvgn in forum Singlespeed
    Last Post: 11-16-2015, 03:47 PM
  3. What's with the Surly Singleator tensioner?
    By KK89 in forum Singlespeed
    Last Post: 06-10-2013, 12:25 PM
  4. X-9 weak spring tension?
    By Mike E. in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-16-2011, 12:12 AM
  5. Surly Singleator question
    By sasquatch rides a SS in forum Singlespeed
    Last Post: 01-12-2011, 07:37 PM
Members who have read this thread: 4
