washers on chainring bolts- Mtbr.com
Results 1 to 11 of 11
    due to some chain issues i've pulled the guard off my crankset to leave only the 44T chainring but now i have too much play in the bolts. I have phoned around and will have to order in shorter bolts but was wondering if anyone else has just tighted everything up with washers.
    this is hardly a blinglespeed [fixie vandessel] so i don't care if she ain't purty, just wondering if there are any problems with the washer workaround
    thanks in advance,
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by dave66
    thanks in advance,
    The washers will work perfectly fine.
    Steamroller
    Reputation: Mattman's Avatar
    Use washers or buy the short bolts
    I've used both, the short bolts are nicer, but washers work and are cheaper. On a junker SS grocery getter I built recently, I had to use about 4 washers per bolt, but it worked fine.
    Two Wheeled and Too Big
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    I presently use two washers per bolt. They don't fit perfectly between the crankarm and the chainring, but tightened down, they don't move at all. That being said, I ordered a set of chainring spacers from Harris Cyclery (they seemed to be the only place to carry the damn things AND not charge an arm and a leg for them) in hopes of 'cleaning up' the look of my crankset. But the washers have been holding up great in the interim.
    Reputation: Sweet_Corn's Avatar
    Be Careful...
    I have used washers with chainring bolts, and have F*cked up the spider pretty bad. The steel of the bolts is much harder than the aluminum of the spider. Just a word of warning, if you want multiple rings on in the future.
    Reputation: Legbacon's Avatar
    Washers
    I just put together an IRO Mark V fixed gear bike and used a 89 XT crank and Sugino 46t ring that I had in the parts bin. The lbs has no short chainring bolts so I took the old Sugino middle 34t ring and cut away every thing that didn't look like a spacer with the dremel. I installed the 46t inboard with the "spacers" outboard. It could look better but it works great.
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    ride it like you stole it
    Reputation: rawdingo's Avatar
    i got some bmx inserts, my lbs gave them to me since they were off of a junker bike.
    If it is free then it's for me!!
    www.justthebonnet.com
    Reputation: Capt_phun's Avatar
    question for travis
    hey travis, nice ride. Stupid question...what are those handlebars actually called?
    Capt_Phun's Riding Blog:
    http://captphun.blogspot.com/
    I better go get my headlamp while I'm sober....ish
    Bars
    I believe they are Time Trial Bars but are commonly called Bullhorns. I can't believe how fast and smooth this bike feels.
    Just a quick report after my first proper ride on my newly-built singlespeed. When pedalling hard or climbing, I noticed some creaking noises going on, and I think this might be coming from the washers, as they do not lie flush with the crankarm. Just a cautionary note when using washers.
    I ordered chainring spacers, but the shop messed up the order. So it'll be a while before I get to the bottom of all this.
    Reputation: pacman's Avatar
    I had chain (1/8") rub on the guard and fixed the problem instead of losing the guard. I put layers of ordinary Scotch Tape on the backside of the guard across the bolt holes. Then I cut holes for the bolts with an Exacto knife. Just the extra space of the tape (12 layers in mycase) was enough to stop chain rub.
  1. Short chainring bolts?
    By B R H in forum Singlespeed
    Last Post: 10-21-2004, 09:08 AM
  2. titanium chainring bolts anyone?
    By Didier Carpentier in forum Weight Weenies
    Last Post: 07-26-2004, 07:41 AM
  3. Snapped a chainring bolt last night
    By Birdman in forum Singlespeed
    Last Post: 07-01-2004, 11:15 AM
  4. Shimano XTR chainring bolts; What material?
    By CODMAN in forum Weight Weenies
    Last Post: 02-10-2004, 01:52 PM
  5. chainring bolts: Al, Ti, mix???
    By FuelForThought in forum Weight Weenies
    Last Post: 01-16-2004, 12:29 PM
Members who have read this thread: 9
