Voodoo Wanga- Mtbr.com
Results 1 to 9 of 9
Thread: Voodoo Wanga
    Jan 2005
    Voodoo Wanga
    I'm considering a Voodoo Wanga as an alternative to a Kona Explosif / Unit
    Anyone got one / tried one?
    Are these 'sliding dropouts' any good, i heard that last years Konas had some
    problems with slipping.
    thanks.
    Bryn Mawr Borracho
    I've got both
    and have had zero problems with either. The finish work on the VooDoo might be a little nicer, but overall I have no complaints with either. (I also think that sliding dropouts are a better solution to running discs on a single than the e.b.b. craze.) Both bikes are good handlers in the singletrack. I put a Psylo 80-125 U-turn on the VooDoo and had a shreddin' good time in Fruita last year.
    cheers,
    Hurl
    carsrcoffins.com
    paintbucket
    Reputation: wooglin's Avatar
    I agree. Don't worry about the dropouts. They work fine.
    When the going gets weird its bedtime.
    Numerous wiring problems.
    Just built up a Wanga One...
    Quote Originally Posted by rekab
    thanks.
    And I love it. Whippy in the tight stuff with a nice spring to the frame, running a 90mm stem with a 100mm Magura fork and it feels spot on. The sliding drop-outs work great and it looks nice too. Sweet bike.
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    The "slipping" issue on the Unit is not an issue after all. I haven't had problems with mine so far, the only problem that I had was stripping the bolts. I replaced the bolts with deep head ones and problem solved.
    The bike rides very nice and don't have any negative things to say about it.
    Reputation: shiggy's Avatar
    Dec 1998
    Both are nice frames. They do have different geometry so I would pick the one that fits you and your riding style better.
    mtbtires.com
    Feb 2005
    rigid fork for wanga
    Only rigid fork I have seen is the Surly Instigator for 100 mm unless custom. Any other forks to choose from I have not seen?
    Dec 1998
    Quote Originally Posted by 27 Feet
    Spicer Cycles has some.
    mtbtires.com
    Reputation: ATXSS's Avatar
    Check yor PM bro!
    Also check out this link to a thread about my Wanga.
    link to thread
  1. Voodoo Wanga One?
    By Badly Wired Dog in forum Singlespeed
    Last Post: 01-03-2005, 12:11 PM
  2. Surly 1x1
    By seely in forum Singlespeed
    Last Post: 09-12-2004, 10:52 PM
  3. Questions to Voodoo Wanga owners
    By Maurice in forum Singlespeed
    Last Post: 07-15-2004, 04:19 PM
  4. VooDoo Wanga Chile (slight return)
    By Hurl in forum Singlespeed
    Last Post: 05-14-2004, 07:19 PM
  5. Voodoo in the US - Probably old news but...
    By Steve-O in forum Bike and Frame discussion
    Last Post: 01-20-2004, 12:22 PM
