using MRP to tension chain- Mtbr.com
Results 1 to 7 of 7
    I ride a .243 4130 with vertical dropouts and would like to convert to single speed. Right now I have an MRP LRP on there with a standard single ring roller as a chainguide, and a 9 speed XT rear setup. Could I use no tensioner in the rear and use the chainguide arm/roller to tension the chain? The roller/arm can be moved up and down along the arm so it seems like I could get good tension by tightening the roller when the chain tension is optimal. If I don't move the roller, I could swing around the arm to tension the chain, as it's BB mount, NOT ISCG mount.
    Converting my cassette hub is not an issue, I will just buy a King Kog and a single speed kit. The hub I am using is a Hadley 108PT hub with Ti fun bolts and Ti freehub body.
    OR, I could just suck it up and buy a surly singleator. Which one?
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    On my Surly Instigator, I attempted this exact method.
    Bottom line, there isn't enough adjustment in this method to achieve chain tension.
    We scrapped the idea.
    Went to the Singulator idea, broke 2 before even leaving the shop.
    Struggled for 2 months with the Soulcraft Convert, with it constantly popping loose under load.
    Best bet....The ENO eccentric disc hub...
    It's a pricey way out..but if you really like that frame...get it done...
    Question...which .243 frame doesn't have horizontal dropouts?
    it's an 02 frame... before they started using the solid plate gusset. My gusset is perforated and doesn't have the maple leaf on it. It also has an MTB BB, which I like.
    Reputation: SSSasky's Avatar
    for a setup like yours ...
    I think the rollenlager would be a better choice. It's burlier than the surly, and seems designed with some hucking in mind (which i assume you do, given the .243 frame). It's hands-down the tensioner i would choose for any conversion setup.
    I, personally, would be scared of hucking with an Eno hub - doesn't seem like the intended use to me ... but i could be wrong. It seems like it might slip on big hits too.
    Check out the rollenlager:
    http://www.rennendesigngroup.com/
    you were right padre... didn't work. I was actually able to connect the chain with no tensioner, but a touch too much tension. So, I guess i'll be going with the rollenlager or singleator.
    Quote Originally Posted by MD Bullit
    It's frustrating, huh!
    It seems like it should work, and be much cleaner look too..but oh well.
    If I were you, I'd try the rollenlager first. That Singleator isn't very stout.
    Quote Originally Posted by Padre
    I am going the other, more expensive rout, and buying the 05 .243 4130 that has horizontal dropouts with a built in tensioner.
  1. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  2. Horizontal dropouts and chain tension questions
    By dirt_donkey in forum Singlespeed
    Last Post: 12-15-2004, 08:07 AM
  3. mrp chain guide woes.......
    By xterraman30 in forum Downhill - Freeride
    Last Post: 05-11-2004, 09:16 AM
  4. Adjusting chain tension - Bianchi SISS
    By AK47 in forum Singlespeed
    Last Post: 04-27-2004, 07:20 AM
  5. MRP Minime System 1 chain guide
    By gemi_adrenolin in forum Downhill - Freeride
    Last Post: 03-27-2004, 06:32 PM
