upgrade recommendations- Mtbr.com
Results 1 to 17 of 17
    I have a stock 2010 Kona Unit that I absolutely love. Thinking about adding some upgrades but don't know where to start. What parts do you recommend upgrading first? I'm looking for something that will actually make a difference in the ride.
    Simple bike, so I would have to say a nice set of wheels would be my first choice.
    Here is mine for ideas...
    EXORCIZE
    Reputation: Ryder1's Avatar
    Quote Originally Posted by phenotype View Post
    What do you feel could be better? Wheels, tires, bar, and saddle should be considered. And maybe shoes - I love my Specialized clipless shoes (stiff and comfy).
    Here's my '11 Unit: Niner carbon fork, Origin8 Space OR2 bar, Easton EA90 100X10 31.8 stem, Origin8 headset, King SS hubs, Stan's Flow rims, Ardent 2.25/Crossmark 2.1 tubeless, '08 XT M775 160/160 brakes, Eriksen 420/27.2 ti post, Fizik Gobi Wing Flex saddle, Stylo OCT 1.1 180mm 32t cranks, King 20t steel cog, KMC Z610HX 3/32 chain, XTR pedals.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    26" wheels. Or 650b. You are pissing away your life.
    I would buy a new wheelset. Rotational weight is where you should be concerned about losing weight.
    You bought a great bike at a great price point. No reason to throw tons of money at it. Sure you could knock a pound or more off of it but it might cost half as much as you paid for your bike.
    Quote Originally Posted by asmallsol View Post
    Nice bike. Like you I added a longer stem and the niner flat top bar with a Specialized road seat that looks like the Selle you have. I stayed rigid with a niner carbon fork, not worth the money over the p2. An easton carbon seat post and lighter tires. Next year I will do some stan wheels and go tubless.
    For a start the carbon bar and a good tire pressure gauge made the most difference in a softer ride.
    2011 Kona unit with some carbon.
    actually, I bought the frame la carte and built it up from there. Ebay for the win.
    beer is good for u
    Reputation: EricN's Avatar
    some stans wheels and tubeless will blow your mind
    I have been toying with the idea of going tubeless. Does it really seem to make a difference, considering the ability to run lower pressures?
    Quote Originally Posted by umarth View Post
    You got that MCF 29 built up yet??
    Quote Originally Posted by p nut View Post
    Nope, currently ****ing up the wheelbuild. I'm hoping it'll be done by the end of the week, so I can give it a test ride somewhere pretty.
    Can't post it here cause it is going to be a 2x10.
    Never trust a fart
    Reputation: frdfandc's Avatar
    It makes a huge difference, especially when running a rigid fork. Tubeless combined with a high volume front tire like a Rampage 2.34, Nobby Nic 2.4, Nevegal 2.4, etc, this allows you to run silly low pressure for a nice ride.
    I just picked up a Unit last week. I'll be ordering a set of Stan's within the next couple of weeks. I've already installed a Ramage 2.35 up front. Improvement over the Ignitor as being able to run a lower pressure with the rigid fork. I also replaced the flat bar for a riser carbon bar, and ordered some Ergon grips for it. Other than that, I might go for a slightly longer stem (90mm might be a tad short), but other than that, I'll end up putting a Niner carbon fork on it come spring.
    How much of improvement with a carbon fork as far as anti shock properties
    does it really make a big difference.
    Quote Originally Posted by Lonecrow View Post
    With the Niner - better on small hits but worse on big hits. If you hit it straight on( same direction as fork legs) there is no give, very harsh. Wish I had spent the money on wheels or a crank.
    wallyman
    Nov 2008
    Hope Gear inches
    I have two single speeds. with 26" wheels
    One has 34x18 for a gear inch of 49.11. 180mm cranks
    two has 32x17 for a gear inch of 48.94. 175mm cranks
    The bike with 180mm cranks seems easier too turn the gear,where 175mm bike I seem to struggle with this set up. What gives? I know I am missing something,I just don't know what it is.
    one chain loop
    Reputation: fishcreek's Avatar
    more tooth count is also smoother to pedal. i have two SS with 2:1 setup, one is running 34x17 and one is 24:12. same tire, same crank arm length, different feel.
    everything sucks but my vacuum cleaner.
  1. Trance X3 Upgrade Recommendations
    By drz400sm in forum Giant
    Last Post: 10-19-2009, 09:15 AM
  2. Upgrade Questions - Need Recommendations
    By underdogoc in forum Bike and Frame discussion
    Last Post: 06-21-2008, 06:15 PM
  3. Upgrade Recommendations
    By cmktech in forum California - Norcal
    Last Post: 04-11-2007, 07:23 AM
  4. upgrade FS or hardtail & recommendations
    By shutterRelease in forum Beginner's Corner
    Last Post: 01-24-2006, 07:29 PM
  5. Commuting upgrade recommendations
    By smaledog in forum General Discussion
    Last Post: 10-06-2004, 08:01 PM
