Results 1 to 5 of 5
    Jun 2010
    Two rear cogs on XXIX
    Hi my xxix has the rear cog with the shimano bmx type (non threaded). My question is if i can add a second cog butted up to the existing one with a spacer in between. I saw that surly makes a dingle but its a track cog. The chain i have is a slim one 3/32. Do i need a tensioner?
    Yeet so hard
    Reputation: tims5377's Avatar
    Oct 2010
    If the bike has horizontal dropouts then you should be fine using them to achieve proper tension. If not, a tensioner is probably your best bet
    Guerrilla Gravity BAMF
    Smash
    Member
    Jun 2010
    What about the dual-cog freewheel from White Industries?
    Rivendell Bicycle Works: White Industries freewheel
    Reputation: asphaltdude's Avatar
    Those are for srew-on hubs, not for cassette style hubs.
    You can put a second cog on the hub, but you will need to deal with a difference in chain length for the different gearings.
    You might consider a dinglespeed. (*runs for cover)
    Ride more!
    Out spokin'
    Dec 1999
    Quote Originally Posted by asphaltdude View Post
    Darn right you better run for cover. Kidding. Actually you're not the lightning rod in this situation. Once the OP puts a second cog on his hub, he's crossed over, regardless of the number of rings up front.
    It's no longer a singlespeed.
    Not that there's anything wrong with that.
    --sParty
    disciplesofdirt.org
  1. How to check rear cogs condition
    By alexzabr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-23-2010, 02:31 PM
  2. 48 39 and 38 teeth rear cogs
    By zerodish in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-20-2010, 07:54 PM
  3. rear deraileur jumping cogs
    By synnie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-30-2007, 02:35 AM
  4. Rear Cogs??
    By russleewood in forum Beginner's Corner
    Last Post: 08-08-2006, 07:08 PM
  5. Rear Cogs..... The good, bad, the ugly....
    By Fast Freddy in forum Singlespeed
    Last Post: 01-30-2004, 11:10 AM
